Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-Atlantic Region > Maryland Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Maryland Chapter Join Chapter, Leader: jr32560
  #1 (permalink)
Old 01-30-2013, 10:07 AM
Iaff113's Avatar
Iaff113 Iaff113 is online now
Garage is empty, add now
Iaff113 is starting off with a positive reputation.
Off topic (Dishwasher)
anyone good with these things? mine has no clogs and a new pump and still wont drain? its a GE portable model
__________________
2006 F-350 Lariat SD 4x4, Blue Spring, Edge Insight CTS, Studs, S&B intake, MagnaFlow Exaust, Upgraded EGR. PMM Coolant Filter. High idle.
  #2 (permalink)
Old 01-30-2013, 10:14 AM
BPofMD's Avatar
BPofMD BPofMD is offline
Old-Timer
2005 Ford F-250
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
How did the problem first start? Are you sure the drain hose is clear?
__________________
BPofMD - Bud - USN-Actively Retired
Maryland Chapter Plankowner
2005 F250 PSD 4X4 LB Crew-cab Arizona Beige / Blue Spring / Gauges / Coolant Filter / SG-II / Peragon Bed Cover/ P/S Filter/ MAG-HYTEC differential cover/
2007 Arctic Fox 30' Fifth Wheel -2012 VW Passat SE TDI (An ALL-DIESEL family)
Join the Maryland Chapter click HERE
  #3 (permalink)
Old 01-30-2013, 10:17 AM
Iaff113's Avatar
picked it up from a friend, wouldnt drain water from the get go, so I bought a new pump and motor, yeah I took the drain line off and made sure it was clear and everything in the bottom of the washer is clear to the pump
__________________
  #4 (permalink)
Old 01-30-2013, 10:42 AM
BPofMD's Avatar
Old-Timer
2005 Ford F-250
You positive that the new pump is actually running? Does it wash ok? Spray?
__________________
  #5 (permalink)
Old 01-30-2013, 10:53 AM
Iaff113's Avatar
yeah runs through all cycles good and strong, but when it comes to drain the solinoid opens the valve and nothing comes out the end of the hose
__________________
  #6 (permalink)
Old 01-30-2013, 11:05 AM
BPofMD's Avatar
Old-Timer
2005 Ford F-250
Electric connections to the pump aren't backwards are they?
You know the solenoid opens - does the pump then start running? Or the pump doesn't run. Does the washer have a timer in it... like a washing machine?
__________________
  #7 (permalink)
Old 01-30-2013, 11:13 AM
Iaff113's Avatar
yeah it opens and pump runs, I can feel water moving through a u shaped house to the drain hose, but nothing at the end. and it does have a timer
__________________
  #8 (permalink)
Old 01-30-2013, 11:22 AM
BPofMD's Avatar
Old-Timer
2005 Ford F-250
Maybe transmission isn't moving the drain opener far enough to really open it.... ot a piece of trash from the macerator is not letting it open.....you'll have to pull the pump and that U tube off to see if anything is in there.....chicken bone????
__________________
  #9 (permalink)
Old 01-30-2013, 11:24 AM
Iaff113's Avatar
lol i wish it would have been that easy, had the pump off and everything else off nothing is blocking anything, im gona try to flip the conections and see
__________________
  #10 (permalink)
Old 01-30-2013, 11:28 AM
BPofMD's Avatar
Old-Timer
2005 Ford F-250
Be careful....who know what sparks may fly!
__________________
  #11 (permalink)
Old 01-30-2013, 11:46 AM
Iaff113's Avatar
still nothing, im at a loss. being beatin by a washer
__________________
  #12 (permalink)
Old 01-30-2013, 01:32 PM
BPofMD's Avatar
Old-Timer
2005 Ford F-250
Have you tried the internet? ASK Jeeves?
__________________
  #13 (permalink)
Old 01-30-2013, 05:21 PM
jr32560's Avatar
jr32560 jr32560 is offline
Maryland chapter LDR
jr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to behold
I had one had a piece of glass in it drove me nuts
__________________
Junior Hardy-
1990 F150 302
1995 E250 4.9
member of the Boy you ain't Right club #4
President of the crap shooters club
  #14 (permalink)
Old 02-02-2013, 07:40 PM
66fdtrucknut 66fdtrucknut is offline
66fdtrucknut has a very good reputation on FTE.66fdtrucknut has a very good reputation on FTE.66fdtrucknut has a very good reputation on FTE.66fdtrucknut has a very good reputation on FTE.
I'm telling ya, appliancejunk.com, just put the make model what it's doing they'll help you, I've fixed my washer couple times,dryer couple times dishwasher and range. most of the times they'll even give you the part # you need.
__________________
62' F-100 SWB uni 223
78' F-350 Dually 400
2012 XL 5.0 3.73
  #15 (permalink)
Old 02-03-2013, 06:40 AM
Iaff113's Avatar
I ended up figuring it out, after looking at the pump and clapper valve, I moved some of the drain and feed lines around and It works. It doesnt look right the way they are going but its pumping.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
