Slight miss...
Slight miss...
How can a person test for a bad cop/plug when there are no codes? I called a shop to get a tune up estimate and he said how with these trucks it could be a bad cop and that he could test for it. I have a reader that attaches to my computer which gives live time info etc. So do I already have the tools, if so what do I look for?
I am having a similar or I should say exactly the same problem but it has never thrown a code. Put new plugs in in july. This problem is driving me crazy as well. Mine usually happens in between 1200 and 1500 rpms but if I step on it it takes off like a rocket. Are there 2 fuel pumps , A low pressure and a high pressure or am I heading in the wrong direction all together? I have a '99 5.4 ltr. and am going to change the plugs and try to test each cop while it's off. The last time this happened (in July) changing the plugs fixed it so it's worth another shot. I also replaced one cop that was underneath a leaky heater hose but didn't solve the problem. I have also thought of using the one new cop and going one by one till I find the bad one. It has never thrown a code or died and only does it at low rpms under a load.
Sorry for the hijack
Bernie
Bernie
Problem fixed!! Went to Lee Auto and picked 1 cop and started with the hardest one(#4 under the heater hoses). Changed it, no difference. Did the same to the #3, #2 then the #1 (the easiest to change)and that was the one. Didn't have try any others the truck is running smooth as silk. It took a little time and patience to track it down but was worth the effort and was only $42.00 out the door and a little time.
Bernie
Bernie
Bernie
Bernie
You have a lot more patience then me, starting at # 4. Good thing you didn't need to go further on the driver's bank. Just changed plugs this weekend again and it reminded me that also having to remove the fuel rail to access #'s 7 and 8 is no fun either.
Glad to hear it's fixed.
Glad it worked out that way. The day I was to take mine, it started making a clicking sound on the upper right toward the front. Took it to the shop and the say timing chain
Bernie
12amracerGlad it worked out that way. The day I was to take mine, it started making a clicking sound on the upper right toward the front. Took it to the shop and the say timing chain
