Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Nebraska Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Nebraska Chapter Join Chapter, Leader: 97nukeford
  #1 (permalink)
Old 01-29-2013, 09:55 PM
Mercmeister Mercmeister is offline
Garage is empty, add now
Mercmeister is starting off with a positive reputation.
1967 thru 1972 Master Cylinder Brakes Lines
Hi Guys! -
I installed a power brake booster and dual chamber master cylinder from a 1969 Ford in my 1966 Ford F100. Does anyone have a pair of donor brake lines for sale that come off the side of the master cylinder? If not, where can I can the fat brass adapters that would screw into the cast master cylinder housing to accept the standard 3/8" brake line nut?
Thank You!
Dan M.
  #2 (permalink)
Old 01-30-2013, 08:55 AM
67nukeford's Avatar
67nukeford 67nukeford is offline
Nebraska Chapter LDR
1997 Ford F-150
My Garage
67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation
Have you tried Napa, to see if they'd carry them? Might have to take the master cylinder in with you.
__________________
Pat W. Nebraska Chapter Leader and Official #1 Slackmaster/ Avid Winter Hater
2006 F-250 "Black" ARP studs, EGR delete, SCT tuner REBUILD THREAD
1967 F-100 4X4
1967 F-100 Project thread
2013 Explorer XLT (wifeys)
CLICK HERE TO JOIN THE NEBRASKA CHAPTER!
  #3 (permalink)
Old 02-20-2013, 04:10 PM
Greetings! -
I installed a 1969 Ford F100 dual master cylinder (MC) with power brake booster in my 1966 Ford F100. If anyone is curious on the brass adapters needed to convert the MC body threaded ports to 3'8" brake lines, here are the part numbers from several manufacturers:
3/8"-24 Inverted Flare to 1/2"-20 Inverted Flare
  • AGS BLF-20
  • Edelmann 258350
  • Weatherhead 7909
  • NAPA BK 6413305
3/8"-24 Inverted Flare to 9/16"-18 Inverted Flare
  • AGS BLF-28
  • Edelmann 258302
  • Weatherhead 7911
  • NAPA BK 6413311
I bought my fittings from NAPA and they were relatively inexpensive and a perfect fit. O'Reilly's, Autozone, RockAuto, etc. will also have them. I am fairly certain these fittings will work on all 1967 through 1972 master cylinders and other years as well. Hope this helps!
Mercemeister
Three (3) 1966 Ford F100's
1966 Mercury Park Lane
  #4 (permalink)
Old 02-22-2013, 02:25 PM
67nukeford's Avatar
1997 Ford F-150
My Garage
Nice, thanks for the info Dan!
__________________
1967 F-100 4X4
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
