single mass flywheel? - Ford Truck Enthusiasts Forums
Old 01-29-2013, 04:53 PM
Christof13T's Avatar
Christof13T Christof13T is offline
Christof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant future
So im about to yank the motor on a 94 to investigate the horrific noise coming from between the motor and tranny.
Its got a 5 speed.
4x4.
All stock.
At idle in neutral there is an ungodly scraping noise..
I will try to take a video and post soonish.
Whats the deal with single mass flywheels?
The trucks owner thinks that is what will cure this problem.
He doesnt complain about any clutch issues or strange vibrations at his feet.
Could this be pilot bearing?
Someone else has suggested that this flywheel may be separating.. maybe?
When i get it torn down and it does turn out to need a flywheel... what part # would you guys recommend?
Old 01-29-2013, 05:23 PM
zarrinvz24 zarrinvz24 is offline
zarrinvz24 is starting off with a positive reputation.
I too am wondering about potential benefits of the single mass flywheel. My current dual mass setup causes the engine to change pitch a bit when the pedal is fully depressed.
Old 01-29-2013, 05:34 PM
fordpride's Avatar
fordpride fordpride is online now
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
You don't have to pull the motor. I bet if you pull the clutch inspection cover you'll have some ball bearings in the cover from the DMF. The DMF is a two piece flywheel that dampins the gear rollover noise. Going to SMF will create some gear roll over noise.
The main benefit is you don't have to worry about the DMF flying apart and destroying the trans or block.
Old 01-29-2013, 06:13 PM
madpogue madpogue is offline
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
^^^^ Also, when you've got the inspection cover off, try to turn the pressure plate a little. If it turns relative to the forward part of the flywheel (part with the ring gear), the DMF is ready to let go.
Old 01-29-2013, 06:36 PM
Either way... oil pan seal, dipstick flange seal, oil cooler, maybe timing cover seal too...
Easier for me to take care of everything at once with motor out.
Any suggestions for replacements.. either single or dual mass...
Old 01-29-2013, 06:45 PM
fordpride's Avatar
Check these guys out. It's the best bang for the buck
Performance Clutch - Ford PowerStroke
Old 01-29-2013, 06:48 PM
fordpride's Avatar
Go SMF and not have to worry about it flying apart
Old 01-29-2013, 06:56 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
I second the Valair
Old 02-01-2013, 03:13 PM
So valair it will be when it comes time to place orders.
Now...
Plucking the motor..
On my 2000 i had to pull the turbo for clearing the cowl...
Looks like i have more room with this 94...
You guys had good luck going str8 up and out or still better to tear down the nose?
Anything in particular i should keep in mind in regards to orientations, alignment issues, or bracing i should do for the trans?
Used a ratchet strap on my 4r100.
I will need to pick up a clutch alignment tool too unless the one for small block gassers fits.
This will be my first diesel flywheel/clutch job.
Old 02-01-2013, 04:24 PM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
Old 02-01-2013, 06:13 PM
What i found under the inspection cover...
[Url]https://www.youtube.com/watch?v=hatMBh9u3CE&feature=youtube_gdata_player[/ame]
Old 02-01-2013, 07:17 PM
Stick a (pun intended) fork in that flywheel; it's done. Speaking of which, when you do the clutch/flywheel, look into a new clutch fork from Ford; IIRC, there's a TSB regarding a new improved version.
Oh, and while you have the cover off, does it have a lip jutting forward from the front edge? If so, grind or snip it off; it's been known to vibrate up against the engine oil pan and "saw" through it. New version doesn't have that lip, but the mod costs zero.
Eeeek, a Fram oil filter!.....
Old 02-01-2013, 07:20 PM
fordpride's Avatar
A new line up tool will come with the new clutch
Old 02-01-2013, 08:18 PM
Yup...
Been scared to see what the air filter looks like..
Trust me... this guy is going to get educated about his truck...
Old 02-01-2013, 08:54 PM
FI460's Avatar
FI460 FI460 is offline
FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.
Minor hijack, but does anyone know if south bend sells just a flywheel? All I see is clutch and flywheel kits...
Dual Mass and Single Mass concerns B-Rad88 Clutch, Transmission, Differential, Axle & Transfer Case 0 12-26-2016 12:01 AM
Dual Mass Flywheel Chevmn56 1999 - 2003 7.3L Power Stroke Diesel 1 08-05-2015 06:56 PM
Dual mass flywheel conversion Manofgod4life 1994.5 - 1997 7.3L Power Stroke Diesel 3 03-21-2015 07:36 PM
Is my flywheel going bad? flainn Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 07-29-2013 07:39 PM
Dual mass flywheel or single ??????? PAVEMENTMAN 1994.5 - 1997 7.3L Power Stroke Diesel 16 09-09-2009 06:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
