Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 01-29-2013, 02:28 PM
MNExpedition2013 MNExpedition2013 is offline
Garage is empty, add now
MNExpedition2013 is starting off with a positive reputation.
2007 Expedition Limited Rythmic Humm 60mph and up
Hi Guys, I just bought this 2007 Expedition Limited 4x4 60,000 miles and didn't notice a few issues when test driving it or they just popped up.
When I am going 60mph+ I hear a rythmic humm from what seems like either exhaust resonance, engine, or a bearing/drive shaft issue. I had the tires which are fairly new, rotated and balanced, which made no difference in the noise. I can not drive through the noise or dull vibration. One of the odd things I noticed, is that the rythmic humm will get less noticable after 5mins of driving or so with the cruise control on. It is both audible and I can ever so slightly feel it in the steering wheel and under my feet.
Had the shop check wheel bearings, they said those are good from what they can tell. The exhaust system is not loose.
I recently changed plugs with SP515's, but did not change COP's or boots. The humm was there before the plug change. Could this be a failing COP causing the engine to run a little wierd at that speed? If I rev the engine from idle it does not rev perfectly smooth to 2000-2500rpm, it seems kind of choppy or slightly bumpy. Does any of yours rev like that in park?
I am kind of at a loss, any suggestions are appreciated. Thanks
  #2 (permalink)
Old 01-30-2013, 11:29 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Mine sort of bumps around in idle at those RPMS. I would suspect tires or bearings, rear end.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #3 (permalink)
Old 01-30-2013, 12:11 PM
berry1234's Avatar
When driving at 60+, put truck in nuetral, sound change? When driving and you hear the hum, turn wheel right or left a bit, sound change? That will load the bearings. Put front tires on back and test. Still there? Still feel it in the wheel?
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
