Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 01-28-2013, 10:04 PM
Fboykin Fboykin is offline
Garage is empty, add now
Fboykin is starting off with a positive reputation.
install interceptor gauge in coin holder hole 2012 Expy?
Just got an Aero Force Interceptor gauge for my 2012 Expedition. I wanted to put it in the dash opening where the "coin holder" piece fits. Gauge is a hair too big! Anyone had any luck fitting one? Tried sanding down the outer diameter of the aluminum bezel to fit the hole? The hole in the dash is recessed (more so on one side than the other) and I think it would be tough to use a dremel tool on the hole because of that. I think it would look almost OEM if I can get the gauge to fit down inside the recess.
Any suggestions? Thanks!
  #2 (permalink)
Old 01-30-2013, 02:01 PM
cstanley44's Avatar
cstanley44 cstanley44 is offline
2008 Ford Expedition
cstanley44 is gaining momentum as a positive member of FTE.
Coin holder? Is that what that is???
__________________
Curtis
2008 Expedition EL Limited
2004 Explorer XLT 4x4 4.6
1970 Buick GS 455 Silver Mist
  #3 (permalink)
Old 01-31-2013, 01:08 PM
yep. Pretty useless as is. Will be a great spot to fit the gauge once I work out a clean, good looking install.
  #4 (permalink)
Old 01-31-2013, 05:55 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
How can you even remove the coin holder?
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #5 (permalink)
Old 02-01-2013, 10:25 AM
You can do a search on this site for "coin holder" and you'll see a lot of posts on it. But basically you just give it a firm tug and it pops out. There were some wires attached to mine (for the 4X4 switch which goes in the spot if you have 4WD -I don't). The coin holder is pretty useless to me, so I'm trying to investigate a nice way of putting the interceptor gauge in there.
I tow a boat a thousand miles round trip 4 or 5 times a year. I'd like to see what temperature the coolant and transmission fluid are running, plus all the other outputs the gauge reads.
  #6 (permalink)
Old 02-01-2013, 10:47 AM
berry1234's Avatar
Thanks.
I would like to put another 12v outlet like on the right side. Seems to be the same size hole.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
