GRRRRRRrrrrrrrrr...PCM fuse keeps blowing! - Ford Truck Enthusiasts Forums
Old 01-28-2013, 04:32 PM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
...and I unplugged the fuel bowl heater!
The Ex left my wife on the side of the road last night and I had to have it brought home on a flatbed.
I checked the F5 chip at the PCM and it's still secured and sealed by the duct tape and it's still firmly connected to the digital switcher.
I SUCK and anything electrical (my mind just doesn't grasp the basics of wiring etc), so if anyone has an idea on what to check, especially if it involves using a multi-meter, please explain like you're talking to a 15 year old. When I read where someone say's to Ohm something out, it's like they're speaking in a foreign language.
Stewart
Old 01-28-2013, 04:44 PM
nlemerise's Avatar
nlemerise nlemerise is offline
nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.
So it blows #30 fuse when you turn the key to the KOEO position?
Old 01-28-2013, 05:36 PM
duck fan's Avatar
duck fan duck fan is offline
Because racetruck
duck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant future
The second you turn the key on, it blows. (I'm at Stewart's right now)
Old 01-28-2013, 05:55 PM
huntke's Avatar
huntke huntke is offline
huntke is starting off with a positive reputation.
isn't that the same one that the fuel bowl heater is on?
oops.... did'nt read close enough
Old 01-28-2013, 05:57 PM
Deluxe06's Avatar
Deluxe06 Deluxe06 is online now
4000 rounds a min
Deluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to behold
Quote:
Peter,
Try unplugging the wastegate solenoid and try changing out the pcm relay. And also check for chafed wires,
Old 01-28-2013, 06:49 PM
howellt39's Avatar
howellt39 howellt39 is offline
howellt39 has a good reputation on FTE.howellt39 has a good reputation on FTE.howellt39 has a good reputation on FTE.
I had this exact same problem a couple years ago, all the way down to "unplugged the fuel bowl heater and no change"
My culprit was a worn spot on the wiring harness atop the DS VC. In my searches I also checked the DS shock tower and the OD wiring at the steering column. Mine was the VC though. Went through a lot of fuses, and ended up needing about 10" of electrical tape.
Old 01-28-2013, 07:19 PM
nlemerise's Avatar
This is exactly what I pm'd Stewart a few hours ago...
Old 01-28-2013, 07:50 PM
Pitcrw6's Avatar
Pitcrw6 Pitcrw6 is offline
Pitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant future
Stewart, I'm like you when it comes to wiring. I need it written down so I can look at it to know what i'm doing. Thats what I get for being in the AF and working on airplanes. We have a book and it tells you exactly what to do and it comes with pictures.
Old 01-28-2013, 08:25 PM
howellt39's Avatar
Quote:
Great minds think alike!
Old 01-28-2013, 10:28 PM
Stewart_H's Avatar
Quote:
Originally Posted by Deluxe06 View Post
Peter,
Will try that tomorrow, thanks!
The drivers side harness atop the valve cover is good to go, no chaffing. (2/1/13 edit to add: To be more specific, the wires on the outside of the valve cover leading to the 42-pin connector was good. I hadn't yet checked the wires on the valley side of the engine)
I didn't think the OD wiring in the steering column could do this, but I'll check it tomorrow too. Already had to replace the one in my old F250 when the OD button quit working.
I know this fuse is for the PCM, the wastegate, and the IDM. Hopefully it'll be something easy.
Stewart
Old 01-28-2013, 11:22 PM
howellt39's Avatar
Stewart
Darnit, was hoping you'd catch a break there.
Good idea unplugging the wastegate, hopefully that does the trick.
Old 01-29-2013, 12:27 AM
SpringerPop's Avatar
SpringerPop SpringerPop is online now
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
As mentioned above, the only things on Fuse 30 are the wastgate control solenoid, the fuel bowl heater, and the two relays that enable the engine to run - the PCM power relay's coil, and the IDM power relay's coil.
The last two are fed through the PCM Diode in the front of the under-hood fuse and relay box. That's the little black thing in the extreme lower right in this photo (ignore "here" and arrow), and unplugs the same as anything else in that box. Be careful, though, it has to go back in the same way it came out, (but it can only fit one way). BTW, the other thing right beside it is a diode for the A/C clutch.
If you remove that little gizmo, the truck definitely won't start, but you will have eliminated half of the things that may be the cause of the short.
If the fuse no longer blows, then it's one of the two relay's coils shorted. Those two relays are identified as the arrowed "here" (the IDM), and the relay that's two above it at the top of the stack (the PCM relay). Pull them out one at a time and see if the short goes away.
If it continues to blow, it has to be either the wastegate solenoid, the bowl heater, or the wire thereto. The current gets from the relay box to those items via a cable that goes through the valve-cover 42-pin connector. Pull that loose and see if the fuse still blows.
If it keeps blowing with the 42-pin disconnected, it's somewhere between the fuse box and the 42-pin connector. Someone mentioned chafing along-side the shock tower.
If not, the short is in the engine valley's wiring somewhere. Since you've already pulled the heater loose, pull the wastegate control solenoid and see.
If you need the wire color (RED/LT GRN), here's a diagram:
http://springerpop.net/F350/PDFs/Eng..._controls1.pdf
It passes through the 42-pin connector on Pin 35.
Pop
Old 01-29-2013, 12:31 AM
Stewart_H's Avatar
Quote:
Originally Posted by SpringerPop View Post
It's the thing in the extreme lower right in this photo
No picture?
Stewart
Old 01-29-2013, 12:35 AM
Stewart_H's Avatar
No picture?
Stewart
Wow, instant picture, LOL!
Stewart
Old 01-29-2013, 12:41 AM
Stewart_H's Avatar
Excellent!
Thanks!
Stewart
Hey Clint (DieselBeast) Your HID's? Stewart_H 2004 - 2008 F150 6 09-07-2012 11:21 AM
2000 Ex Spring Conversion loleuiha Excursion - King of SUVs 13 04-14-2011 02:40 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
