33" tires on 1995 F150 XL 2WD? - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 01-29-2013, 05:15 PM
CoreLokt's Avatar
CoreLokt CoreLokt is offline
CoreLokt is starting off with a positive reputation.
I called my local 4 wheeling shop about installing these mods and the first thing they asked me was if I had the parts or not, seems they dont mind using your own parts. I also know that my fuel mileage is going to go down, i was just saying that I would like to keep the gears as high as possible to keep fuel efficiency as high as possible.
  #32
Old 01-29-2013, 05:19 PM
bluemtn95ford's Avatar
bluemtn95ford bluemtn95ford is offline
bluemtn95ford is gaining momentum as a positive member of FTE.bluemtn95ford is gaining momentum as a positive member of FTE.
I agree, I would say just have them do the alignment and supply the parts. who knows you may not need new bushings.
And yes up sizing your tires will lower mpg below your current 13-14. especially before you re-gear. Just make sure you gear it right and you will be back to similar power but still slightly lower mpg with 32's.
  #33
Old 01-29-2013, 05:20 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Quote:
Your gearing logic is wrong. 4.10s would net you better milage than 3.08s in this case
  #34
Old 01-29-2013, 05:24 PM
CoreLokt's Avatar
Oh I got you. Since the tires are so big, the mileage would be better with the lower gears?
  #35
Old 01-29-2013, 05:26 PM
Correct. It would put the engine closer to is power band
  #36
Old 01-29-2013, 05:28 PM
CoreLokt's Avatar
Ok that makes sense. So you think I should just get the springs and let the alignment shop worry about the bushings?
  #37
Old 01-29-2013, 05:30 PM
Keeping high gears won't necessarily keep your mpg higher. If you have high gears your motor will have to produce more power to turn the tires, which, of course uses more gas. LOWER gears will convert the power of the motor better and so turn the tires easier, but you will still use more gas because the gears require more turning, thus giving you more power, but still less mpg. I think this is how it works, again there are some guys on this site with WAY more experience on gearing than me.
  #38
Old 01-29-2013, 05:33 PM
Yes, let them do the worrying lol
  #39
Old 01-29-2013, 05:35 PM
CoreLokt's Avatar
Haha I don't know if I want to because then I'll be the one worrying when they come out with the bill!
  #40
Old 01-29-2013, 05:53 PM
CoreLokt's Avatar
So in your opinion, I should just get the springs, install them myself, then take it to an alignment shop and let them take care of the rest?
  #41
Ryan0214's Avatar
Ryan0214 Ryan0214 is offline
Ryan0214 is starting off with a positive reputation.
My understanding is that, with lower gears, your engine will transfer the power better, resulting in slightly better mpg, but the faster you go, the more your engine will be revving, resulting in lower mpg. Higher gears are better for cruising at higher speeds, but lower gears are better for torque.
  #42
Old 01-29-2013, 06:48 PM
Bob Gervais's Avatar
Bob Gervais Bob Gervais is offline
Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.
A few things of note:
Nobody is bashing you for not knowing everything. That's why forums like this exist, for information and help when you need it. It's also a place that can pass misinformation, such as installing F250 leaf springs on the front of your 2WD. Simply put, that's a horrible idea.
Your idea of installing the springs and letting the shop worry about the camber bushings is correct. Camber bushings can be a pain in the *** to get out, even with air tools and torches.
Check with the shop doing the work, to compare pricing of you bringing them parts to install, and them supplying parts and labor. Many shops will charge a higher labor rate to install parts that you bring them, and sometimes you end up not really saving much money at all.
You're going to hate the acceleration of your truck with 3.08 gears and 32" tires. Also, what Brad mentioned is exactly correct. Your fuel mileage will improve with 4.10s, simply because it puts the engine in the correct powerband. Larger diameter tires numerically lower your final drive ratio. It's a lot to explain, but perhaps a google search of "final drive ratio" or something like that would turn up an article or writeup that would be helpful.
  #43
Old 01-29-2013, 07:12 PM
CoreLokt's Avatar
Thanks Bob, I will go ahead and order the springs. I'll keep y'all posted!
  #44
Old 01-29-2013, 07:16 PM
Looking forward to seeing it done! There is another member here with a lifted 2wd Flareside that looked great. I haven't seen him post in a while.
  #45
Old 01-29-2013, 07:19 PM
CoreLokt's Avatar
Ok the springs are officially ordered. Are there any other things I should look to have to replace before I can be aligned? I know when I took our Expedition, they said it needed new ball joints before they could align it so we got some and installed them ourselves.
Tire/rim Combo Recommendation/Ideas NewEnglander 1978 - 1996 Big Bronco 21 02-15-2013 11:04 PM
Wheel/tire questions 06silvercrew 1999 to 2016 Super Duty 18 09-22-2010 12:23 PM
Max Tire Sizes MisterCMK Explorer, Sport Trac, Mountaineer & Aviator 0 04-18-2007 12:25 PM
maximum tire size hsfbfan 1987 - 1996 F150 & Larger F-Series Trucks 3 05-24-2006 07:06 AM
33x10.50 tires on 92 F150 4x4...no lift 92Custom Brakes, Steering, Suspension, Tires, & Wheels 21 07-14-2002 03:57 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
