1998 4.6 Triton - Head Gasket? - Ford Truck Enthusiasts Forums
Old 01-27-2013, 08:22 PM
jjoel jjoel is offline
jjoel is starting off with a positive reputation.
New truck to me and already have that sick feeling in my stomach.
Truck was advertised with a slow coolant leak. Figured I would trace the leak down and get it repaired no issues. Anyway, working on it this evening I take a close look around the oil filler area and notice the dreaded milkshake color.
I drained the oil out of the truck and the oil actually came out nice and black. Is the headgasket the only area that would cause the oil/coolant mixture? Supposedly the truck has never been overheated.
At any rate, on to find articles on how to pull apart a 4.6L Triton head. I'll see if I'm up to this challenge.
Old 01-27-2013, 09:40 PM
shooter123 shooter123 is offline
shooter123 is gaining momentum as a positive member of FTE.
could just be condesation
Old 01-27-2013, 10:28 PM
Hope youre right.
Old 01-27-2013, 10:57 PM
vaper vaper is offline
vaper is starting off with a positive reputation.
Pressure test the cooling system first to rule out external leaks
F-150 5.4L blown head gasket? matt1260 1997 - 2003 F150 6 09-28-2016 03:33 PM
any problems with the 4.6 triton ??? JF5speed Modular V8 (4.6L, 5.4L) 25 04-26-2016 09:00 AM
Coolant lose Wayne242 Modular V8 (4.6L, 5.4L) 11 08-10-2013 07:32 AM
97 4.6 LITER MOTOR USEING COOLANT KAHNE9 1997 - 2003 F150 17 01-02-2010 08:38 PM
'97 4.6L Triton Leaky Heads croatoan 1997 - 2003 F150 3 10-12-2009 08:12 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
