1965 F-600 NP 435 Transmission Question
Just acquired a 1965 F-600 dump truck. The transmission pops out of reverse gear. Thanks to NumberDummy for helping me decode the warranty tag, I now know it has a New Process 435 four speed transmission. Will any 2WD NP 435 out of most Ford trucks work in the bigger F-600, or is it a different transmission altogether? Any information about this will be greatly appreciated.
C4TZ-7017-A .. NP435 Input Shaft-9 3/8" long / 1964 B/F/N500/700 330 / 1965/69 B/F/N500/700 240/300 I-6 & 330 / 1970/72 B/F500/700 240/300 I-6 & 330.
C5TZ-7017-B .. NP435 Input Shaft-8.991" long / 1965/72 F100/250 2WD I-6 & V8 / 1966/72 F100 4WD I-6 & V8.
C5TZ-7017-C .. NP435 Input Shaft-10.661" long / 1965 F100/250 4WD I-6 & V8 / 1965/72 F350 I-6 & V8 / 1966/72 F250 4WD I-6 & V8.
I was hoping to avoid this thread, as there are too many variables, that takes way too much time to research. But since you've opened the can of worms...
If you have the time, could you find the input shaft length of a 280V clark out of a '69 F600 with a 361? I looked but get easily confused by the parts book.
Clark 280-VO-4 ~ trans # C7TA-7004-G ~ parts list #70.9J
Clark 280-VO-8 ~ trans # C9TA-7004-Y ~ parts list #70.9J
C8TZ-7017-B .. Input Shaft-Use with C7TA-7004-G & C9TA-7004-Y
9 15/32" long / 24 helical teeth / 25 clutch teeth / 10 splines.
Bill
Do you know if any of the 5 speed transmissions you listed below (or above) have 5th gear as an overdrive or is 5th gear direct drive only?
Text-Section 70, page 38 ~ 1969 5 speed transmissions: B/C/F/N500/800 I-6 & V8.
thanks
thanks
Bill
thanks
thanks
Jared96f150
06-20-2016 01:39 PM
ID Scrounger
04-27-2016 01:15 PM
juang316
09-20-2013 11:30 AM
