2000 f250 7.3L worth? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-27-2013, 04:57 PM
bluemtn95ford's Avatar
bluemtn95ford bluemtn95ford is offline
bluemtn95ford is gaining momentum as a positive member of FTE.bluemtn95ford is gaining momentum as a positive member of FTE.
So this is my first post in this section of the forums. I'm looking at a 2000 f250 7.3L supercab long bed 4x4. The stereo system got taken out of it awhile ago. It's got a rough inside (tears and stains in the seat). Also there's something wrong with the front differential. When we put it in 4 wheel drive the front axle would catch and make a nasty cracking noise. Like the locking hubs were jumping teeth? the guy rebuilt the motor at 289000 miles. He bought new pistons, glow plugs, cleaned up the crank shaft, and watever else can be done in the rebuild. So the motor itself has about 25,000 miles on it. He also rebuilt the tranny he says at the same time. The body has a few dents and the passenger door has a small crunch in the bottom corner. He's asking $8000, which I think is high with the condition and 4x4being out. I was wondering what it would take to rebuild the front 4x4system myself. Or what it would cost to have a shop do it. I was thinking of offering the guy $5000 so I could save some money for getting the stuff mentioned fixed. Do you think this is reasonable? I'll need to sell my 1995 f250 extended cab 351 before I can buy this truck. Thanks for your time and help guys.
Old 01-27-2013, 05:30 PM
acf6's Avatar
acf6 acf6 is offline
acf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputation
Id give him like 3000...
Old 01-27-2013, 05:38 PM
onebadv2 onebadv2 is offline
onebadv2 is starting off with a positive reputation.
I have been looking for a crew cab diesel over the last couple of weeks and have found numerous trucks in that price range that do not have the troubles this truck has now. I think I would keep looking......be patient, the truck you want is out there.
Old 01-27-2013, 06:13 PM
Thanks for the reply guys. He has receipts and pictures of everything hes done. he's been a professional mechanic for 4 or 5 years. He had a machine shop do all the boring of the heads and such. I've been looking for a 7.3L of this year for awhile (99-02) and they all seem to be a little pricey for me. I'm willing to get a truck that needs a little work and do it myself for 5 grand or less. I dont care so much about the interior, I'll be buying seat covers and stuff nayway. and it needs to be able to get muddy and stuff. I'm mostly concerned about the 4wheel, which I need for hunting and such.. he's had this truck on the market since November starting at $12000. It has a good strong motor and tranny as far as I could tell from the test drive. I just don't have 10K to spend and thought this would be a good alternative to get the diesel without the price? Thanks again..
Old 01-28-2013, 07:17 AM
mnpowerstroke99duty's Avatar
mnpowerstroke99duty mnpowerstroke99duty is offline
mnpowerstroke99duty is starting off with a positive reputation.
I've seen complete front axles on craigslist for $700-$800.If its a hub you could get one off ebay fairly cheap or you could get some Warn manual hubs for $200-$300. If its the transfer case $400-$500 on craigslists. I'd say if you can get it for $5000-$6000 go for it.
Old 01-28-2013, 11:10 AM
Kdr358's Avatar
Kdr358 Kdr358 is offline
Kdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to behold
Quote:
I have too agree, it sounds pretty beat up. How much rust has set in? Also if the original injectors were re-used I'd keep at least 2k aside for a new set. If the turbo is original set aside another 1k. At almost 300,000 miles its time for, a complete brake system overhaul, hoses, fluid, pads, rotors, calipers. Not to mention the 4x4 issue. It could be simple ESOF hubs or need a pricy transfer case. Can you post pics of the truck?
Old 01-28-2013, 04:48 PM
I believe he replaced the injectors and Im not sure about the turbo. I know he did alot more than just do a standard rebuild. I would post pictures but I dont know how Ill make a temporary garage album for it so you guys can see it. As far as rust, there is none. He has the bed sprayed with bed liner wich seems to be barely used. He also had the bottom 6" of the truck sprayed with the same stuff, which hasn't seen alot of wear. Be sure to check my garage for pics. Thanks guys.
Old 01-28-2013, 04:54 PM
Also, there are a few dents in the body but none have rusted yet. I also forgot to mention that the front hubs (which are manual) are hard to lock in and slightly rusted around the housing on the outside of the wheel. This is why I thought it might be a problem with the hubs..
Old 01-28-2013, 04:55 PM
acf6's Avatar
If the bottom of the truck has bed liner, chances are theres rust under it. 99% of times i see someone put bed liner on the bottom of the truck, its hiding rust.
Old 01-28-2013, 07:37 PM
I'll be sure to check that. Thanks. although I didn't notice any when I looked it over.
Old 01-28-2013, 09:09 PM
lllateralus lllateralus is offline
lllateralus is starting off with a positive reputation.
That does not sound like a good purchase.
4x4 needs work, unknown cost, (diff?) beat up, seats torn, nearly 300,000 miles on everything but the motor with questionable rebuild.. no go.
*especially for 5 grand. 8 grand is a complete joke.
KEEP LOOKING.. right after you buy that POS, the perfect truck will pop up on craigslist. Trust me.. just wait it out.
Old 01-28-2013, 09:24 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002 Redneckfordf2502002 is offline
Redneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputation
I would tell him $2500 take it or leave it and really there I am being generous there isn't much truck left of it being high mileage and 4x4 not working.
Trav
Old 01-28-2013, 09:34 PM
Wow... Really? I seriously doubt he would take it. Especially considering the year of the truck and his work in the rebuild. I guess I can start low and see what he'll take? The thing is, I need to sell my truck before I can buy a new one. And I can't afford to go without a truck for long. (hauling hay, horses, etc.)
If I can sell mine for 4-5k I think I'de offer him about a grand or two less for repairs. Sound like a good idea?
Also, with the truck being rebuilt about 25,000 miles ago, I have a lot of life left in the motor and tranny. Versus a nicer truck I buy for 10k with 200-300k miles. I figured I may save money in the long run. Thanks guys I'm getting closer I'm just still not sure lol
Old 01-28-2013, 09:41 PM
I would definatly start low to me it doesn't look like it is that good of a deal to get from him. I would keep looking also you may find a better deal.
Trav
Old 01-28-2013, 09:47 PM
Bigpipes 35's Avatar
Bigpipes 35 Bigpipes 35 is offline
Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.
Quote:
Trav
I think that number is crazy, would you let your 7.3 truck with 4 wheel drive and from what I can tell from the pics not a bad body go for $2500. I know I wouldnt, I think I would try to pinpoint where the noise is coming from in the front end and if its just a hub the truck is worth between 4 and 5 grand all day long.
5.4 3V expert advice needed to replace phasers vs whole rebuild? 66 bronco roadster 1999 to 2016 Super Duty 49 08-12-2016 10:32 AM
motor just quit, no idea why birddogcrazy 1999 - 2003 7.3L Power Stroke Diesel 18 07-28-2016 08:57 AM
I'd like your opinions on a possible purchase. rch10007 Excursion - King of SUVs 7 06-01-2014 06:22 AM
Engine Swap 302 to a 7.3 IDI vin K? Athanasius 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 12-23-2013 07:09 AM
If you were rebuilding a 460 what would you do? nonrev321 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 24 01-19-2013 09:39 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
