Thoughts on possible upgrades
Now that I think we have my excessive fuel consumption issues solved, I have been thinking about the following for my 5.4L F350:
1. Gibson headers & super truck exhaust
2. BBK 75MM throttle body
3. K&N cold air kit
4. 5 Star Tuner (or any tuner for that matter)
5. SPD Y-Pipe
What are the opinions out there of these upgrades? Are they worth it?. Does anyone think their are better options? Keep in mind most things I am able to do here need to be done in a driveway, I do not have a garage to work in.
3. K&N cold air kit
5. SPD Y-Pipe
3. K&N cold air kit
5. SPD Y-Pipe
3. K&N cold air kit
5. SPD Y-Pipe
3. K&N cold air kit
5. SPD Y-Pipe
3. K&N cold air kit
5. SPD Y-Pipe
What he said. ive done them all (minus the throttle body) and they were pretty much useless besides the y pipe. definitely got some power from that
I appreciate this info for sure. I have reservations on the K/N hype. This is what I am thinking, and correct me if I am wrong. The K&N claims that there is increased airflow through the filter to the engine. More air, more fuel, more power. That makes sense to me. BUT if you are ramming more air through the filter and the K/N cold air duct that is mounted to the factory Mass Airflow Sensor that feeds into the factory 70mm diameter throttle body in reality you are feeding no more air into the engine. There is still the restriction on the 2 components. I think Bernoullis principle applies here. So I was thinking installing the larger diameter throttle body, not a spacer to increase that airflow and try to locate a high flow MAF if such a component exists. I am new to working on the newer engines, my last real truck was a 79 bronco w/ a 351M & 4speed on 33's. She was easy to work on and alot of fun to play with. I sure do miss carburetors and Caps & rotors.
More air = less filtering. And its not like were feeding a forced induction engine here, just a N/A one so i imagine the factory intake flows more than enough. i got sporadic and did the zoodad mod, which involves drilling a hole in front of the intake for more air... but really it was just free and i was bored
Great, sounds like I will get the Y pipe, and install a nice throaty sounding muffler. She is a little to quiet, I like a deep rumble tone. One of my friends has a BullyDog tuner that he offered to sell me since he sold his 05 F150 w/ a 5.4. I am not quite sure if it will be compatible with my 02 f350. I was not able to locate my truck on their application charts for the gas tuners. What I am looking for are firmer more positive feeling shifts and less searching. This is the 1st automatic vehicle I have owned in 14 years, I have always felt automatics were sluggish and lazy.
The wife is talking about getting me a tuner for fathers day, I was thinking about the Superchips Flashpack. I am really looking for better shifting. I know the Bully dogs are not compatible. Anyone running these things like what they do? How well do they adjust the transmission shift points and firmness?
I second the 5 star tunes. Give mike a call, he was very helpful to me and the tunes are the best I have seen on a 5.4 SD. I run the 93 octane performance tune primarily and I love it. The SPD Y-pipe is also a great mod, but if you are running anything over stock tire size I would also recomend deeper gears.
