1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
newbie 62 uni cab mounts
Old 10-01-2013, 06:57 AM
sb62uni's Avatar
sb62uni
sb62uni is offline
Hello, name is Anthony, located upstate n.y. picked up a decent 62 unibody short bed over last winter... it seems I've searched high and low with no luck, hoping some one here can point me in the right direction!
I'm looking for the front cab to frame mount rubber pads and bolts. Any information would be greatly appreciated! (I already have the metal Mounts just need the rubbers as mine are squished pretty bad
Great site will be coming here often.
Old 10-06-2013, 04:49 PM
sb62uni's Avatar
sb62uni
sb62uni is offline
Any help would be greatly appreciated ... if the information is already posted somewhere here let me know, still learning how to navigate the site
Old 10-17-2013, 08:55 PM
jimgraf's Avatar
jimgraf
jimgraf is offline
5th Gear
I've got the same truck, but a long bed. Check our Macsautoparts.com. I'm pretty sure they have the pads (maybe not as a separate item, but certainly as a kit that includes the pads and bolts.
Jim
Old 10-17-2013, 10:04 PM
garbz2's Avatar
garbz2
garbz2 is offline
You need to buy a regular cab kit for 61 to 64 and throw away the rear mounts.
New rear frame under mounts and blocking can be made for reinforced rubber and new red oak blocks. No one makes these.
The Rad support kit for 61 to 64 is the same.
you can get them just about anywhere.
Garbz
Old 10-18-2013, 11:37 AM
sb62uni's Avatar
sb62uni
sb62uni is offline
Thank you! Exactly the answer I was looking for!
timmyboy76
12-22-2010 03:34 PM
78ford351m
10-01-2010 09:10 AM
78ford351m
09-08-2010 09:30 PM
HiPressure
03-14-2004 01:03 PM
ymurf
02-16-2004 11:45 AM
Quick Reply: newbie 62 uni cab mounts
