trans locked up motor??????
I just bought a 95 f250 4x4 with the 460. The guy i bought it from had a trans slipping towed it to the shop when the shop went to pull it in they started it put in gear and engine died. The motor is now tight w no movement either direction with a bar obo it. Is it possible the trans is holding the motor tight? What can I do? Please help!!!!!!!!!
Kitson82, If the truck was towed for quite a distance without removing the driveshaft or the axles, the trans is probably burnt completely up and peeling metal inside. When they cranked it up and put it in gear, the front pump froze and the gear that turns the convertor is seized or burst and won't let the convertor spin with the engine. I'm an old Ford Tech who did trans for 30 years and seen this happen several times. The trans oils from the front pump when the engine is running and if the driveline is turning and the engine isn't, no lubrication is happening at needed points in the trans, causes things to start seizing. Try pulling the trans leaving the convertor bolted to the flex plate and see what happens. If you can't get them to separate, you'll know for sure.
I think you might not be able to without damaging the pump or convertor. I've seen guys take all the trans to engine bolts out and let the trans jack sit a couple of inches below the pan, rock the trans up and down to try to burst it loose. At least if you still have the convertor attached to the flexplate when you get the trans out, you can see if the engine will bar over, good luck.
wmiller
02-16-2009 03:07 PM
