1978 electrical problem, will not start - Ford Truck Enthusiasts Forums
Old 01-26-2013, 09:53 PM
tw's Avatar
tw tw is offline
tw is starting off with a positive reputation.
Unhappy 1978 electrical problem, will not start
Hello,
I just purchased a 1978 F250 Ranger Lariat, AT, A/C, Cruise, Tilt, 460.
It has a few problems. I just drove it a couple miles to my buddies place, and now it will not even engage the starter.
The lights work, but do not dim when i turn the key. I tried to jump it, but not even a click from the solenoid. I checked the connections, they are all good.
Now my wife is giving me a really hard time about the truck I bought that stranded me on its first trip from the house.
I would greatly appreciate any ideas.
Old 01-26-2013, 10:42 PM
Redtires019 Redtires019 is offline
Redtires019 is starting off with a positive reputation.
Take the wire of the "S" post on the starter relay and put a test light on it. If it is not getting power then it is somewhere in the ignition switch or wires. If it is getting power then the relay may be bad. Start there
Old 01-26-2013, 11:02 PM
montana_highboy montana_highboy is offline
montana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud of
Don't rule out a faulty NSS (neutral safety switch) try "jiggling" around the shifter while starting the truck...
Or better yet just temporarily bypass the NSS (after you rule out the solenoid and ignition switch).
Old 01-27-2013, 10:48 AM
fmc400's Avatar
fmc400 fmc400 is offline
MSEE
fmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud of
Agreed with all the advice above.
Old 01-27-2013, 12:09 PM
Notjoe Notjoe is offline
Notjoe is starting off with a positive reputation.
Try tapping on the starter and solenoid with the key turned to start just to see maybe if that is seizing up
Old 01-27-2013, 12:33 PM
tw's Avatar
tw tw is offline
I ran a wire from pos battery terminal to srarter post on solenoid with key turned and it did turn over. So does that mean a bad solenoid?
Old 01-27-2013, 01:34 PM
fmc400's Avatar
MSEE
Quote:
Aside from that being very dangerous (heavy inductive load that could spark near a battery), no, it does not tell you if you have a bad solenoid yet.
Either the solenoid is bad, or it's not getting a trigger signal. You need to check for power getting to the 'S' post first as Redtires019 describes above. Why ask for advice if you're just going to do your own thing anyway?
Old 01-27-2013, 01:40 PM
tw's Avatar
tw tw is offline
I did all of that yesterday before I asked. I just wanted to put out all of the info I had. I have not been able to check the truck since yesterday. It is still at my friends house.
Old 01-27-2013, 01:41 PM
fmc400's Avatar
MSEE
Since it sounds like you have done some other diagnosis that was not listed in your original post, please list out all the things you have checked.
You're saying you have verified that 12 volts is getting to the 'S' post of the solenoid with the key in START?
Old 01-27-2013, 03:03 PM
tw's Avatar
tw tw is offline
Yesterday I ran a jumper to the starter just to make sure it wasn't stuck. I have not yet done any other diagnosis since it is parked at my friend's house and i didnt have my tools. I will be heading over there soon and use the advice i have been given so far and will report back. Thank you all
Old 01-27-2013, 04:09 PM
tw's Avatar
tw tw is offline
The s pole on the solenoid does not get power, with key on or start position
Old 01-27-2013, 05:03 PM
fmc400's Avatar
MSEE
That's your problem then. This has nothing to do with the starter solenoid. The problem is with the ignition switch, or the wiring in between. With the key in START, the RED with BLUE stripe wire that leaves the ignition switch and goes to the 'S' post of the solenoid should have power.
Applying power to the 'S' post of the solenoid is what actually makes it close. The solenoid will never engage without this.
Old 01-27-2013, 06:52 PM
tw's Avatar
tw tw is offline
Thank you all for your help, I had to hotwire it to get it home and out of his driveway. I checked out the wiring behind the ignition switch and it is a mess. The previous owner had spliced in multiple places. I really appreciate all of the input. I will pick up a new switch and do some wire repairs later this week or weekend.
Old 01-27-2013, 09:37 PM
fmc400's Avatar
MSEE
No problem, best of luck.
The College/University Budget Build Thread Aaron-71 1973 - 1979 F-100 & Larger F-Series Trucks 235 08-02-2016 01:41 PM
New Member! Here's my 1978 F250 Custom 4x4 F250_Pat 1973 - 1979 F-100 & Larger F-Series Trucks 29 12-14-2015 06:13 PM
The University Budget Build Thread Aaron-71 Manitoba / Saskatchewan Chapter 123 07-07-2015 06:37 PM
Rad Hoses for Super Cooling Rad Negrey 1973 - 1979 F-100 & Larger F-Series Trucks 9 08-08-2014 01:03 AM
Exhaust Manifold Gasket Replacement - 351M sraab928 1973 - 1979 F-100 & Larger F-Series Trucks 21 12-08-2013 09:31 AM
Tags
electrical, relay, solenoid, starter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
