1999 F-250 Super Duty 7.3
Old 01-28-2013, 03:07 PM
twg1966's Avatar
twg1966
twg1966 is offline
Trying to Gain Knowledge
You can screw the adapter into the top of the HPOP and it will give you the LPOP pressure. Check out the following thread.
https://www.ford-trucks.com/forums/1...ure-maybe.html
  #32
Old 01-28-2013, 05:23 PM
ronb521's Avatar
ronb521
ronb521 is offline
I installed the gage and I have 50 psi at the LPOP. As soon as the injectors quit oiling the engine gets in a strain. I now assume both sides are not oiling when the oiling quit however I never noticed the oil quiting on the passenger side when I was checking that side. Is there a pressure regulator on the HPOP that could be causing this problem or a blockage between the HPOP and the injectors?
Ron
  #33
Old 01-30-2013, 09:29 AM
ronb521's Avatar
ronb521
ronb521 is offline
1999 f-250 super duty 7.3
!!!Uptate!!! The symptoms are the truck starts basically ok. Within a minute the injectors quit oiling and now instead of just running bad the truck quits. Since our last talk, I have installed a gage at the top of the engine at the HPOP also. I already had one installed at the oil filter. The one at the oil filter reads 50 and the one at the HPOP reads 60 until the injectors quit oiling and then the engine quits. I have replaced the IPR and the ICP as well as previously the IDM, valve cover gaskets with new wiring and one pigtail. I don't know what the problem is. The engine has new oil and filter.
  #34
Old 01-30-2013, 10:58 AM
twg1966's Avatar
twg1966
twg1966 is offline
I am at a loss. It sounds like you have a restriction somewhere. I don't have a clue where that could be. But I will watch and see.
  #35
Old 01-30-2013, 12:07 PM
ronb521's Avatar
ronb521
ronb521 is offline
where is the screen in the hpop?
ron
  #36
Old 01-30-2013, 01:28 PM
ronb521's Avatar
ronb521
ronb521 is offline
I found the main screen resevoir and my truck doesn't have one. Is there another place where the oil could be blocked either before it gets into the hpop or after it goes through the hpop such as an inline filter?
Ron
  #37
Old 01-30-2013, 01:41 PM
twg1966's Avatar
twg1966
twg1966 is offline
I wish I had an answer for you Ron. I am at a loss as well. There are more experienced individuals out there on FTE that will hopefully give you a shout out when they finally get to this thread.
  #38
Old 02-07-2013, 02:24 PM
ronb521's Avatar
ronb521
ronb521 is offline
Thanks John, Ted and others who have helped me. I have had the truck running for about a week. After the IDM, ICP, IPR and then the HPOP, I got the truck running. It was still acting up and I put in a CPS. It then ran consistant but had a miss. I took it to a shop and #8 cylinder was missing. I put in the 3rd injector replacement and it is now running fine.
Ron
  #39
Old 02-07-2013, 03:52 PM
JOHN2001's Avatar
JOHN2001
JOHN2001 is offline
That's great to hear... Told ya # 8 was the most common... Happy truckin
  #40
Old 02-07-2013, 04:40 PM
twg1966's Avatar
twg1966
twg1966 is offline
Dang, I hate it when the darn fix has to be a new injector. That truck must like to eat those things for breakfast, if that is your third one.
Glad you have it going again.
  #41
Old 02-10-2013, 02:25 PM
ronb521's Avatar
ronb521
ronb521 is offline
I guess it all the miles. Hopefully this is my last fix for a while. Thanks again guys.
Ron
  #42
Old 02-10-2013, 02:31 PM
gengine's Avatar
gengine
gengine is offline
I've been watching since day one, and glad to see ya got it fixed!
jeffohc
12-04-2017 01:42 PM
mechmagcn
12-14-2016 04:01 PM
Docbandy
09-20-2016 08:55 AM
grizzweideman
04-30-2011 04:13 PM
grizzweideman
04-29-2011 10:18 PM
Quick Reply: 1999 F-250 Super Duty 7.3
