4.6 misfire on cylinder 3&4 about to go crazy
Old 01-26-2013, 06:22 PM
slimfitz's Avatar
slimfitz
slimfitz is offline
Hello all, My wifes explorer has developed a misfire on cylinder 3&4 consistently. I did have cylinder 2 misfire once. But have not had it come back. The explorer is a 2006 4.6 limited with 130000 miles. Originally it was misfireing on cylinder 3. So I swapped the coil packs between 2&3. Cleared the codes. Still got a cylinder 3 misfire. So I went and bought new plugs for it. Cleared the codes. Still misfire on cylinder 3. Swapped injectors 3&1 .I took it out and romped on it and now i get cylinder 3&4 consistently misfireing. Now I got me to thinking that the only side that is misfireing is the pass side. I was going to swap o2 sensors but couldnt get the driver side out so I went and bought a new o2 upstream for the passenger side. Still get 3&4 misfire. Thought it might be fuel related so I pulled the filter. It was kinda tough to blow through so I put a new fuel filter in it. How the hell can I check the fuel pressure without a fuel fitting? Please anyone have any advice before I pull all my hair out? I am now thinking it might be fuel pump, plugged cat, or low compression
Old 01-26-2013, 07:00 PM
aquanaut20's Avatar
aquanaut20
aquanaut20 is offline
Slow down, take a deep breath. stop guessing...
You need to validate the engine first.. remove all plugs, cut the fuel and spark, WOT and take a compression reading on 3&4....
Get back with the results..... Philip
Old 01-26-2013, 07:16 PM
slimfitz's Avatar
slimfitz
slimfitz is offline
Well I wanted to do a compression test today but I dont have the right adapter. I am going to try and buy one local tomorrow. But I may have to order one.
Old 01-26-2013, 09:42 PM
aquanaut20's Avatar
aquanaut20
Be prepared to follow up with a leak down test on the engine.... Philip
Old 01-27-2013, 03:02 PM
slimfitz's Avatar
slimfitz
slimfitz is offline
Yes I am already thinking the worst. I own a cylinder leak down gauge. But I need the adapter to use either that gauge or my compression gauge. The adapter is not available anywhere local and I had to buy one online. Should be here some time next week. I am not really digging how Ford changed up everything. What was the purpose of using a spark plug thread different than any other engine ever? Why did they remove the schrader valve for the fuel system? How are we supposed to check fuel pressure?
Old 01-30-2013, 05:09 PM
slimfitz's Avatar
slimfitz
slimfitz is offline
Well its confirmed. Cylinder 3 has bad rings and the head gasket between 3&4 is popped. This sucks. I cant believe this motor at 130k is this bad. I change the oil every time the light comes on withen a few days. I just cant fathom it being this bad. Ive had cars where I never changed oil and never had any issues!
Old 01-30-2013, 06:00 PM
aquanaut20's Avatar
aquanaut20
Sorry for you grief, that is exactly what I expected...
What are you going to do about it, pull and R&R?.. Philip
Old 01-30-2013, 06:08 PM
slimfitz's Avatar
slimfitz
slimfitz is offline
Yes im already looking for a used motor with good compression.
Old 01-30-2013, 09:15 PM
aquanaut20's Avatar
aquanaut20
Did you consider doing a re-ring on the one cylinder and a head gasket, in frame..
Of course that depends on the results of the compression in the other holes... Philip
Old 01-30-2013, 09:44 PM
slimfitz's Avatar
slimfitz
slimfitz is offline
I am going to pull the motor this weekend. I will open it up and see what it looks like. I did not think about doing just one set of rings. I may judt rebuild the motor anyway. Seems junkyard motors are 1500 bucks. I figure im close to that in parts. Machine shop might not be to bad if my heads are ok. My cylinders were.
1- 168 170
2- 169 170
3- 160 150 150
4- 140 145 140
5- 168 168
6- 168 170
7- 160 165
8- 165 170
With cyl 3 on TDC air was rushing out dipstick tube
With cyl 4 on TDC air was rushing into cyl 3
Old 01-31-2013, 06:42 AM
slimfitz's Avatar
slimfitz
slimfitz is offline
There may be a chance it is still the head on cyl 3. Yesterday i was pissed when i found the motor bad. I forgot to put some oil in to check the rings. So today i am going to rerun the compression check on both 3&4 with a little bit of oil in the cylinders
Old 01-31-2013, 11:12 AM
aquanaut20's Avatar
aquanaut20
Ah!
I had wondered about the second set of readings, seemed tight enough to indicate valve issues.... Philip
Burniestanley
1997 - 2003 F150
01-25-2019 10:21 AM
jtart2
1997 - 2003 F150
09-26-2018 06:32 AM
terry274
1997 - 2003 F150
12-01-2017 04:11 PM
nevrenufhp
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
12-05-2004 09:18 AM
DieselDude78
03-16-2003 10:13 PM
Quick Reply: 4.6 misfire on cylinder 3&4 about to go crazy
