"Truck wont stay going" - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 01-26-2013, 05:52 PM
Texasranger73 Texasranger73 is offline
Texasranger73 is starting off with a positive reputation.
My 1997 F350 OBS PS Won't stay going!!!
*Replaced Alternator
*New batteries and Terminals
*New mechanical fuel pump
*New FuelFilter
Someone help? It will start and I can drive a good amount then it'll die and it'll crank over and then it'll end up starting again then go about less then a mile and die again. Sounds like a fuel issue??? Help someone. Should I clean the Screens in the fuel tank or what?
Old 01-26-2013, 06:27 PM
stainlessstroker95's Avatar
stainlessstroker95 stainlessstroker95 is offline
stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.
Sounds more like a CPS issue. Get one from ford and try it.
Old 01-26-2013, 06:58 PM
Action4478 Action4478 is offline
Action4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputation
Are you saying it is temp related ?
Old 01-26-2013, 06:59 PM
N/A ************
Old 01-26-2013, 07:00 PM
I think my truck doesn't like the cold, but it'll start and drive for a good bit but it'll just die like someone flicked switch off and it stays dead then I gotta wait a little bit and start it up and it'll go but die again.
Old 01-26-2013, 07:55 PM
I just bought a Cam Shaft sensor from Autozone. 24.89 hopefully this fixes the problem tomorrow.
Old 01-26-2013, 08:50 PM
Good luck but the parts store cps are not any good. Most the time they are bad right out of the box. It is best to get one from Ford or an international dealer.
Old 01-26-2013, 09:42 PM
Really? I might as well take the part back then... Even if it's a duralast its bad? Stainless anymore info you think might be wrong I pretty much gave the run down on whats happening to the truck. I did lose power on the high way and I had to push on the pedal to keep the truck going then it just died. I was also at a stop light on a incline and it died on me when I went close to a halt. But each time I had to get it towed back because I kept trying to start it and it wouldn't start. Could it be injectors?
Old 01-26-2013, 11:20 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
I will agree with the above, try a ford or international CPS first. If that doesn't fix it, the second thing I would try is replacing the IPR O rings.
Old 01-27-2013, 12:57 AM
A good scanner is a good investment also.
Old 01-27-2013, 09:23 AM
If I replace the IPR O-Rings and the CPS and it's still doing it what would be the source. I'm trying to figure out if I could diagnose where it's coming from... I can't break the bank. What would be a good scanner? Should I get one that just plugs in?
Old 01-27-2013, 11:25 AM
tshrager's Avatar
tshrager tshrager is online now
tshrager has a good reputation on FTE.tshrager has a good reputation on FTE.tshrager has a good reputation on FTE.
Quote:
Like Rick said, does it die when it comes to temp or does it not matter if its hot or cold?
Old 01-27-2013, 02:57 PM
It don't matter what temp. their is when its outside it'll do it no matter what, but it's only worse when it's cold.
Old 01-27-2013, 04:06 PM
tshrager's Avatar
Like stated then, get yourself a ford or international CPS and go from there.
HELP! Truck keeps dying!!!! gordeaux 1999 - 2003 7.3L Power Stroke Diesel 15 06-17-2007 09:06 PM
Haveing trouble like ironmc, But not sure its belt +massacre+ Ranger & B-Series 24 01-31-2006 09:18 PM
help my truck won't stay running 7sixf150 1973 - 1979 F-100 & Larger F-Series Trucks 27 01-09-2006 10:09 AM
My 302 is "gasping" for air...or something El Bronco Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 09-22-2005 10:25 AM
Just quits running! strangebru 1973 - 1979 F-100 & Larger F-Series Trucks 9 03-13-2004 03:32 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
