Got my first truck on a trade, how'd I do? Lots of pics & questions!
So I'm 33 now and finally own my first truck , an 84 F150 4x4 with the 300 and a 4 speed.. I think. It claims 3 speed + overdrive, reverse is bottom-right. Which trans is this exactly? Odometer says 54k and change, 5 digit odometer.
I was selling an 89 Toyota Cressida with a blown head gasket for $500 and someone offered the truck, straight across trade. I was initially going to sell the truck but I like it a lot! Definitely keeping it.
Truck runs great, I tested the 4x4 and everything seems to work fine. I'm in CA and it's tagged until August, so all it'll cost me to drive it until then is the $15 transfer fee. It also appears that the SMOG equipment is still there and hooked up. I think I got a pretty good deal, what would you guys ask for this truck if you were selling it?
Got a couple issues I want to take care of ASAP. The fuel system is running on the front tank only, and the gauge doesn't work. The rear tank is there so I'm guessing the control valve went out and someone rigged it to run on the one tank only. Is there a diagram online of all the components in the fuel delivery system? Are there fuel level senders in both tanks?
The speedometer is downright hilarious. It spins like a propeller, faster when you drive faster and in reverse when backing up. Likely cause? Where is the damn release button on the headlight ****?
Heater doesn't work. The blower is fine but the slider controls are shot. Are there guides online for rebuilding this? A/C doesn't work either and I'd like it to eventually.
I have a ton of questions but I'll save some for later hah
on
Post the transmission code on the safety certification lable and one of us here can decode it.
There looks to be some serious issues that need to be taken care of that I'll mention further down.
Other issues that you should take care of ASAP that you haven't mentioned.
Your Brake master Cylinder seems to be leaking. Your brake booster has wet deposits on it that looks like brake fluid. This could be something as simple as a master cylinder cover gasket or lid, or something more serious.
Negative Battery Cable. It's totally misrouted from where it belongs. The negative battery cable is supposed to run down along the passenger frame connect to the frame with a inline crimped on tab, then continue to one of the starter mounting bolts to ground the engine. You also seem to be missing the firewall to engine ground cable. That and with the wrong color of the engine is why I think it may have had an engine replacement at some time.
The radiator is the smaller narrow radiator. From the looks of the pictures it had a wider radiator in it at one time (essential for A/C). The top radiator hose is for the wider radiator and it has been contorted and made to work with the narrow one. The top radiator hose shows signs of bulging at the thermostat housing, and that's not good. The radiator top mounts are missing some bolts and part of it's metal support bracket. You are also missing your fan shroud or fan guard.
That and the radio install has little to be desired really. A proper mounting kit would fix that.
With all those problems, it's worth around $500/$1000 dollars around here. It may not take very much $$$ to double that figure though, if you fixed things.
Awesome info guys, much appreciated. Luckily I am fairly mechanically inclined and have done plenty of my own work on cars. The last project I did was swap a radiator in my 94 Sable the morning we were supposed to leave for vacation, the previous radiator cracked at the worst time. Got it done by myself and off we went. Popping the hood on this beast and seeing all the empty space was glorious. I'm used to working on cars with crammed engine bays.
I see many visits to junk yards and pick-n-pulls in my future..
I've done master and slave cylinder swaps before, is this fairly straight-forward? Also I notice a lot of these rust badly, is there a newer design which will stay looking fresh if properly maintained?
I've also never done differential oil changes before but it seems pretty simple. Is the front diff changed the same way the rear is? Anything I should watch out for when doing these and the others? I'd like to change all the fluids. Is there anything in the front hubs that would need servicing?
I thought that little radiator looked odd. Are all the larger radiators interchangeable or are there differences between auto/manual/etc. I'm also curious how to identify factory or dealer A/C? Luckily it looks like everything is there, although the hoses are rubber and I haven't seen that before.
Thanks for the detailed replies. Most forums are not quite so helpful.
Some of the controls are cable operated, so just see what's wrong, some oil may be all that's needed. Again a junkyard would be a good place to search. This is not a common problem, as the speedo is not a common problem either, so you should be able to get something good from a used truck. The sending units in the tanks and the fuel switching valve going bad are a very common problem, so you want to buy new for these.
The truck came with the wheels in this picture, but only 2. Are they a popular enough style that I could get a complete set? Anyone know the name/manufacturer?
Attachment 293654
Attachment 293654
on
Interesting... So am I.
The front hubs should be repacked with grease everytime you do a brake job.
I can tell you have dealer A/C because you instrument cluster bezel and your passenger dash area has been cut for the dash registers. Also non Factory-A/C trucks have vents below the dash in the kick panels, and the heater core is in the engine compartment instead of in the cab. Also Dealer A/C uses standard A/C hoses with clamps. Factory A/C uses moulded hoses with fittings. As you get to know your truck you will be able to pick out the differences in dealer or Factory A/C at a glance, especially looking at the differences in the wrecking yards.
Mountain Ranch here, east of San Andreas.
Looks like I have to get the truck smogged even though the tags are good until august. I haven't bought/sold many vehicles in CA, thought fees/smog were good the whole year regardless of whether it changes hands. Truck is running great though and appears to have all the equipment, we'll see how it goes.
Thanks again for the info guys, going to start on getting the two tanks running first since that'll help with smog.
on
As for the smog, it's only good for 6 months for title transfers.
Having two tanks is a definate plus with smog checks. The evaporative emissions test is easy to fail. They pressurize your gas tanks, and check for leaks, sometimes creating leaks in the process. Factory Dual tanks are exempt, but both have to be working otherwise they will do a evaporative emission test. They still test your gas caps.
Fix the tank, and I would take care of that battery cable. No need to advertise to the smog tech that someone hokey pokey'd things.
