front hitch install with photos - Ford Truck Enthusiasts Forums
Old 01-26-2013, 05:05 PM
blue95f250460 blue95f250460 is offline
blue95f250460 is starting off with a positive reputation.
I installed a Curt front hitch on my 1995 F250 (460) and have a couple of questions.
1. Did I install this hitch correctly?
The hitch I ordered was designated for 4x4 models only, my truck is 2WD. A completely different designed hitch is offered for 2wd models, that looks like a traditional frame mounted hitch (rear hitch style). However, it hangs low...so I bought the 4x4 hitch model (for ground clearance) after reading that the frame horns/front frame design is the same between 4x2 and 4x4 f-series.
2. Is there anything you would change? mounting hardware...etc. other than what I have used?
The reason I ask if I mounted the hitch correctly is because of the strange way this hitch bolts up. The bolts that came with the hitch were way to short, so I purchased longer grade 8 bolts and nuts to tie the sides of hitch to the frame rail. see below pics:
Should I upgrade the bolts that hold the bumper (& now hitch ) to the frame? I have used spacers (washers) to push the bumper forward due to 33inch tires that rub (the bumper) without the extra clearance. However due to the added thickness of the hitch the bolts are just barely long enough....see pic below:
I bought the hitch at etrailer.com Curt model #31310, here is a link:
Front Hitch for 1995 Ford F-250 and F-350 - Curt 31310
I will use this front mounted hitch to move trailers (back them up/park them) and the occasional 4x4 mud extraction/anchor (as the tow rig)
I now have a class three front hitch, class five rear hitch, 15k fifth wheel hitch and 15k goosneck that mounts to the 5th wheel rails via adapter; just about 300 pounds of hitch weight...I think I have covered all towing hitch's for this 460 beast tow rig,...short of a big rig 5th wheel, am I missing a hitch type?
Old 01-26-2013, 06:09 PM
nvrsatisfied84 nvrsatisfied84 is offline
nvrsatisfied84 is starting off with a positive reputation.
yea u mounted it right the reason the bolts they sent u are too short is because the 4wd frame ends are boxed where the side bolts go to the frame and urs isn't boxed
Old 01-26-2013, 06:33 PM
Quote:
I wondered about that, it makes perfect sense. If the frame was boxed (on 2wd) the bolts that came with the hitch would have worked.
So why is the 2wd frame not boxed? Does a 4wd frame need the boxed frame up front for component mounting?...etc. or is it just to stiffen the frame up for the flex encountered off road?
I asked the question regarding the difference in frames between 2wd and 4wd and every response (from multiple forums & friends) was that there was no difference.....well, I guess I found at least one of the differences.
Thanks for the help.
Old 01-26-2013, 08:21 PM
Phy's Avatar
Phy Phy is offline
Phy has a good reputation on FTE.Phy has a good reputation on FTE.
The 4x4 trucks have leaf springs up front, and the frames are boxed for the front spring shackles.
CPS Teardown woodnthings 1999 - 2003 7.3L Power Stroke Diesel 47 03-27-2016 01:22 PM
05-07 Harley Headlight Install woodnthings 1999 - 2003 7.3L Power Stroke Diesel 27 07-09-2014 08:07 PM
1997 Ford E350 Shuttle Bus Batt. Issues getbuck911 1968-2013 Full Size Vans 16 08-12-2013 05:46 AM
New here, New To Me 77 F150!` Vegasw0lf 1973 - 1979 F-100 & Larger F-Series Trucks 12 07-22-2013 10:37 PM
how to re-attach tailgate panel? blue95f250460 1987 - 1996 F150 & Larger F-Series Trucks 4 12-30-2012 04:21 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
