Dual Inlet Single outlet Muffler
My flowmaster muffler is the exact opposite, single in, dual out (to create dual exhaust) Its a 50 series, which is quiet on idle / cruising but is loud when your foot gets heavy
Flowmaster 50 SERIES HD HEAVY DUTY MUFFLER
What size are your headpipes?
How much do you want to spend?
The Bear River 22" WickedFlow is stainless, pretty quiet and reversible due to it's design.
It is perforated, not louvered like some other brands.
Untitled Page
I used a giant school bus muffler from the Walker heavy duty catalog with 2 1/2" inlets and a 3" stainless universal Magnaflow tailpipe.
http://www.walkerheavyduty.com/catal..._InletSize.pdf
You can see all the dimensions here.
This 22822 muffler is really heavy gauge and the internal volume is immense -so the tone is deep and mellow- but it has no packing to wear out or hold moisture.
All I had to do was weld flanges on the inlets and make a new rear hanger.
Untitled Page
Yeah, the pipes that were on the motor, on my 91 F150 all bolted up fine, just a little too long at the rear tire. Had to cut it off there. My Bronco thinks its an F150 anyhow.
I seen some other straight six Bronco guys that put that pipe on fine and about the bottleneck. Preciate the info, it prolly will be cheaper to just buy the pipe.
Eac95z28
12-16-2009 11:52 AM
