eec id help
Old 01-26-2013, 02:47 PM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
eec id help
i have a few computers layin around and its been a while since ive been on this project. . .i can find a few but cant find them all.
calibration code e9d
efi-sd20b
e9tf-12a650-ae1a
some help would be appreciated. i suspect its out of a 460, which is what i want. thanks in advance.
Old 01-27-2013, 05:19 AM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,164 Likes on 919 Posts
Old 01-30-2013, 07:50 AM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
Thank you sir. Is there any way to determine which ignition module was used (gray or black) by the codes alone?
Old 01-30-2013, 08:40 AM
DPDISXR4Ti's Avatar
DPDISXR4Ti
DPDISXR4Ti is offline
Seeing as how the catch-code is typically only three characters, it's not going to tell you much, in and of itself. But once you determine what model year it's from, you should be able to figure it out from there. I think '94 was the first year for the black TFI, but not sure if the change-over from gray to black was consistent with the model-year change.
Old 01-30-2013, 08:55 AM
rla2005's Avatar
rla2005
rla2005 is offline
Ford did not start using the black colored ICM CCD-style Ignition system on these trucks until 1994. Your truck uses the gray colored Push-Start ICM. The PCM you are referencing is listed for use on a 1991 F-series truck therefore it is designed for use with a Push-Start style ignition (gray ICM).
Old 01-30-2013, 08:00 PM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
thanks for the replies. i cant remember what i got all these out of, but im positive the 460 comp was a brick nose, so that solves that.
GreaseGun Joe
08-16-2015 02:03 PM
grldben
08-11-2013 07:01 AM
perryau1996
10-03-2011 11:33 AM
Allen_70
10-23-2010 01:56 PM
93Sunplex
04-07-2007 03:43 PM
Quick Reply: eec id help
