weak flow through HVAC vents - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-26-2013, 04:42 AM
rocklobster87 rocklobster87 is offline
rocklobster87 is starting off with a positive reputation.
2008 F-250 XL/5.4
Truck has consistently weak air flow out of all interior vents. Mode and blend doors appear to be functioning properly. Defrost vents seem to be more restricted than others flowing almost no air at all. Recirculating improves air flow some but not much. I used a long blow gun and a vacuum attachment to clean out the HVAC inlet in the cowl (which did have some pine needles and such built up on it) and found no noticeable difference in flow. I am assuming the inlet and possibly the heater core and evap. core are simply plugged up with dirt and that I will be removing the dash to deal with this. Just want to make sure I'm not overlooking something before I do.
This vehicle is used for Wildland Firefighting and sees a lot of dust/dirt and a lot of A/C use.
No noticeable difference in flow whether at max heat or max a/c.
Truck has been acting this way since around the 25,000 mile mark.
Thanks in advance.
Old 01-26-2013, 07:28 AM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Pull the blower and see if you can see the evaporator core. It's probably clogged with dust or maybe even a critter nest.
Old 01-26-2013, 10:32 AM
_red rocket_'s Avatar
_red rocket_ _red rocket_ is offline
_red rocket_ is gaining momentum as a positive member of FTE._red rocket_ is gaining momentum as a positive member of FTE.
Honestly I'm not certain...but do these trucks have a cabin HVAC air filter which seems present on a lot of modern vehicles?
If airflow was reduced at 25k miles, that is the first thing I would check for, a dirty/clogged cabin air filter.
Old 01-26-2013, 11:36 AM
Cabin air filters were a dealer installable item but they were not factory original. However, a restricted cabin air filter will ONLY affect the flow of air from outside. It won't restrict airflow when in recirculate mode.
You have to find the portion of the system where all airflow must pass through. That would be the evaporator core and the housing where the blower resides.
Old 01-26-2013, 01:06 PM
Visit My Gallery
thank you for the replies.
No cabin filters. I have removed the blower motor and observed it's operation. No signs of blockage visible from the port for the motor. No material in the hamster wheel whatsoever. Swapped in a motor from another rig and no change. Motor makes 4 distinct speeds. Mode switch directs air to selected vents and selected vents only. Just no damn flow.
There's actually two trucks under my care with this same issue.
Any info on these cabin filters available through the dealer?
Are they located in the cowl or in the HVAC housing?
I was considering a custom setup to stave this off in the future but bolt on would be nice. .
Old 01-26-2013, 01:17 PM
Runky's Avatar
Runky Runky is offline
Runky is starting off with a positive reputation.
I worked on a 2005 F250, 5.4 from up north (New Jersey) and it had a similar problem. Ended up being a rusted heater core, weak blower motor and rusted/burned up blower motor resistor. Sounds like you have a plugged heater core, especially since you found some pine needles in the intake. I haven't heard of anyone doing a cabin air filter mod but I bet the dealer version isn't the only one out there.
Old 01-26-2013, 08:17 PM
From what I gather ford did and maybe still does offer a cabin filter kit but it only applied/applies to the F-150, Expedition and Navigator. Seems as though both a company know as "Cab Fresh" and Wix offer conversion kits but I cant find part #'s or any real info on either.
Old 01-27-2013, 08:38 AM
If the heater core was gunked up, he'd get regular airflow when the heater control was set to "cool" as this setting bypasses the heater core.
Old 01-27-2013, 07:26 PM
Runky's Avatar
Quote:
Right, he stated that the airflow was the same in a/c or heat so maybe both are plugged up? Since there isn't a cabin air filter is it possible that dirt and debris might be in both the heater core and the evaporator?
Old 01-28-2013, 02:39 AM
BigAlsPSD's Avatar
BigAlsPSD BigAlsPSD is offline
BigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud of
Have you checked up under the dash below the glovebox, to ensure there is not a plastic sack or similar blocking the recirc air flow.
Old 01-28-2013, 04:47 PM
Quote:
Yeah no obstructions anywhere. I'll be ripping into these later on this week. I'll be sure to post up with the results.
Old 01-28-2013, 04:54 PM
Quote:
Not positive on these but in HVAC boxes I've been in before all air flow was diverted through the evaporator first, then through the heater core by the blend door, Thus if the evap is clogged, flow will be restricted regardless of temp. This is what allows you to have the A/C on with the temp set to high and get warm dry air out of the vents.
I didn't want to just assume everything was as I thought it would might be and thats a big part of the reason I posted up.
Old 02-01-2013, 07:29 PM
Runky's Avatar
Did you fix it
Just checking in to see if you found the problem. Haven't been on the sight for a while.
Old 02-01-2013, 08:45 PM
Been busy working on other stuff. Had the A/C evacuated today. Plan on tearing into it on monday. Definitely intend to post up with the results.
Old 02-06-2013, 12:13 AM
Tore into this today. Found two AA batteries and a set of keys sitting on top of the door that directs air to the defrost vents, keeping it from opening beyond a slit. Also the evaporator was almost completely clogged with dirt. Looks like we'll be conversing with our drivers about keeping **** off the dash and using recirc all the time when on dusty roads (thought that might have been a given).
Thanks to all who chimed in.
Getting Heat...an on going battle in the cold. granny_rocket 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 01-20-2015 07:48 AM
A/C Issue. Only Blows From Defrost Vents jtexfisher 1968-2013 Full Size Vans 21 01-26-2014 05:38 PM
1986 winnie (Winnebago RV) ford 460 heater/AC control drusher 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 08-12-2011 09:38 AM
HVAC fan slow to start blowing lhansman 6.0L Power Stroke Diesel 2 07-25-2010 06:21 PM
no heat and trickling water not your usual one rrumba Expedition & Navigator 28 01-27-2009 09:28 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
