Well the other day i was driving out of town on the high way randomly my tranny was making a bunch of noise so i pulled over and, it wouldn't smoothly go into any gears and neutral when i let the clutch out was 2nd gear, i let it sit for a few minutes got better so i waited an hour or so then drove it home and changed tranny fluid that night, do you think that it just over heated? there wasn't a bunch of metal in the old fluid was pretty nasty though, and a little low. any thoughts on why it did this and any damages it could have caused?
Not a cheap trans to fix on. Replaced the D/M flywheel, new clutch and t/o bearing for mine @ 88k miles, those flywheels are not a good thing. Customer let one go too far and broke off a piece of the engine block.
Replaced my D/M flywheel w/a LUK kit. Sounds like that's what's up with your rig, and it sounds like the trans just might have a problem. I hate paying for fixing on a ZF.
