collection of parts 1956 f100
extent that grabs wheel back and forth? this kit front disc brakes, which is certainly adequate 5 x5, 5 "?
FRONT DISC BRAKE CONVERSION KIT
Bolts choice of wheel pattern disc brakes to truck properly
with no modifications. Designed to support calipers with
perfect alignment for even pad wear and safe dependable
service.Includes: Loaded Calipers, Rotors, Inner Bearings,
Outer Bearings, Grease Seals, Brake Hoses, Banjo Bolts,
Spindle Nuts, Dust Caps and a Basic Bracket kit with
Caliper Brackets, Spacers, Hardware & Instructions.
Note: kits include all pieces shown but differ in bracket style.
5 on 4 1/2 kit . . . . .5987-450 . . . . . .$395.00 kit
5 on 4 3/4 kit . . . . .5987-475 . . . . . .$395.00 kit
5 on 5 1/2 kit . . . . .5987-550 . . . . . .$395.00 kit
1355-30 5 5 1/2 2.75 $80.00 $110.00
1356-37 6 5 1/2 3 3/4 $80.00 $110.00
1357-37 7 5 1/2 3 3/4 $85.00 $120.00
1357-40 7 5 1/2 4 $85.00 $120.00
1357-45 7 5 1/2 4 1/2 $85.00 $120.00
1358-37 8 5 1/2 3 3/4 $95.00 $120.00
1358-40 8 5 1/2 4 $95.00 $120.00
1350-50 10 5 1/2 5 $95.00 $130.00
to rebuild a 292 engine, I have seen this kit do you think?
Ford 292 Engine Kit Rering Mercury 1955 56 57 58 59 60 61 62 63 64 Bearings | eBay
Hi, I need your help, I'm with a list of orders to complete a project of a 56 f100, I put the list in order and I would like vuetro comment if something is wrong:
SPEEDWAY:
Description Quantity Price Total
1953-64 F100 Y-block Headers, Plain
9308422
UpdateDelete $199.99 $199.99 In Stock
Smithy's Glasspack Muffler, 22" Body, 2" I.D. Inlet/Outlet
91013106
UpdateDelete $34.99 $69.98 In Stock
1948-56 Pick-Up Deluxe Brake Kit, 5 x 5-1/2"
91031964
UpdateDelete $279.99 $279.99 In Stock
Selected Kit Components
SKU Description Quantity
91631986 1948-56 Pick-Up Basic Brake Kit, 5 x 5-1/2" 1
91031068 11.75" Ford F-150 B.C. Brake Rotor 2
91031044-L Caliper for 1971-1976 Impala 1
91031044-R Caliper for 1971-1976 Impala 1
9193382 Speedway Street Organic Brake Pads 1
912TLM11949 Tapered Outer Wheel Bearing Cone 2
912TLM11910 Outer Wheel Bearing Cup, Tapered 2
912TL68149 Inner Tapered BRG Cone 2
8352300542 GM Caliper Slider Bolt 4
912S9406S Seal 2.00: ID x 2.625" OD 2
5502492 Dust Cap - 910-31068 Rotor 1
6178568 Rubber Brake Line Hose Set For 7/16"-20 Calipers 1
6173513 7/16" Crush Washers 5/PK 1
91031311 Removable Brake Tabs for Rubber Hose 1
Plain Steel Header Reducer Kit - 2-1/2" In, 2" Out
91013751
UpdateDelete $14.99 $14.99 In Stock
1953-54 Ford Pickup Rear Leaf Springs
580154R
UpdateDelete $369.99 $369.99 In Stock
1953-56 Ford Pickup Front Leaf Springs
580154
UpdateDelete $349.99 $349.99
Mid Fifty:
Product +Ship Core Price Qty Total
Brake Adjust Hole Cover Rubber
Part Number: 0543-RB $0.00 $0.00 $1.25
REMOVE
Bumper, Front Chrome, With Brackets
Part Number: 0600-CH $12.50 $0.00 $199.00
REMOVE
Hub Cap, SS, Ford Script
Part Number: 1300-SCPT $0.00 $0.00 $28.50
REMOVE
Beauty Ring, Smooth 15
Part Number: 1301-SM15 $0.00 $0.00 $28.50
REMOVE
Wheel 15"x7", Bp-5.5 Rs-4 Stl
Part Number: 1357-40S $20.00 $0.00 $85.00
REMOVE
Wheel 15"x8", Bp-5.5 Rs-4 Stl
Part Number: 1358-40S $20.00 $0.00 $95.00
REMOVE
Carpet Complete, Bench, Black
Part Number: 2160-BLK $0.00 $0.00 $259.00
REMOVE
LMC:
Log In
Qty. Part # Description Unit Price Amount
47-3913 WIPER ARM-RH 1 REQ 10.95 $10.95
In Stock
47-3912 WIPER ARM A/R 10.95 $10.95
In Stock
47-3994 WIPER BLADE-12" SNAP-IN 2 REQ 9.95 $19.90
In Stock
40-2516 ****-WIPER SWITCH-ON/OFF 1 REQ 6.95 $6.95
In Stock
48-8810 LMC 3000 TRUCK COVER 99.95 $99.95
In Stock
40-1210 GROMMET-MIRROR ARM 2 REQ 1.95 $3.90
In Stock
40-4163 EXHAUST MANIFOLD GASKET SET 12.95 $12.95
In Stock
49-9106 DOOR SKIN-LOWER-LH 39.95 $39.95
In Stock
49-9070 INNER DOOR BOTTOM-LH 44.95 $44.95
In Stock
41-1526 COWL VENT GASKET 1 REQ 6.95 $6.95
In Stock
49-9068 ROCKER PANEL-LH 39.95 $39.95
In Stock
49-8816 FLOOR PAN-LH 89.95 $89.95
In Stock
42-0812 BLACK WEATHERSTRIP ADHESIVE 6.95 $6.95
In Stock
41-1552 FUEL NECK GROMMET 1 REQ 8.95 $8.95
In Stock
41-1621 BATTERY HOLE COVER SEAL 1 REQ 6.95 $6.95
In Stock
41-1521 COWL TO FENDER SEAL SET 1 REQ 9.95 $9.95
In Stock
41-1501 HOOD BUMPER KIT-6 PC 1 REQ 7.95 $7.95
In Stock
49-9663 EXTERIOR RUBBER KIT-CUSTOM 1RQ 99.95 $99.95
In Stock
40-0118 CAB MOUNT BOLT KIT-14PC 1 REQ 9.95 $9.95
In Stock
40-0116 CAB MOUNT BUSHING KIT-10 PC 12.95 $12.95
In Stock
43-0952 RADIATOR SUPPORT MOUNT KIT 14.95 $14.95
In Stock
49-7142 WINDOW CHANNEL KIT 1 REQ 159.95 $159.95
In Stock
SPEEDWAY:
9308422
91013106
91031964
91013751
580154R
580154
Mid Fifty:
REMOVE
REMOVE
REMOVE
REMOVE
REMOVE
REMOVE
REMOVE
LMC:
Log In
In Stock
In Stock
In Stock
In Stock
In Stock
In Stock
In Stock
In Stock
In Stock
In Stock
In Stock
In Stock
In Stock
In Stock
In Stock
In Stock
In Stock
In Stock
In Stock
In Stock
In Stock
In Stock
The list you put up seems to have a lot of duplicate function parts, like some for disk brake conversion, some for stock drum brakes, others that will not work with the changes you want to make, for example hubcaps and beauty rings will only work on original size and type wheel. Where is the truck you bought?
You might want to call Mid Fifty directly, the part of the USA they are located in a lot of the people speak Spanish (Mexican, not Castillian) so there is likely someone there that can speak with you in your language.
The reason people found it funny is "groin" in English most often refers to the area between a man's legs!
This is the truck that I bought
Ford : F-100 Custom in Ford | eBay Motors
the truth is that the translator sometimes does not work very well, it is normal that it will be funny groin .....
I wanted to put some wheels like this:
replace the original front brakes for disc brakes like this:
replace the suspension to lower the truck 3 ", and put a new exhaust manifolds.
A rest from all those other things on the list
#29
Who do you want to buy your parts from
the van will pick me a company of New York, which will send it to me in a container, they can save me three weeks to buy the spares, I would have to buy and the shipping would be to New York .
What wheels would have to ask to be like the black truck?
Thanks for the help.
* if you see something you would have to ask for the truck feel free to comment
#30
