hot and bothered!
hot and bothered!
97 f250 4.6l engine pegs the temp gauge after start-up. the oil pressure light comes on then after a few miles down the road anti-freeze blows out the pressure cap (15LB) then the temp goes down ,the oil light goes off and everything is normal. no its not the thermostat, i changed that and it still does it. whats up with that?
Check for hydrocabons in the coolant.
it overheats because the antifreeze is not circulating past the thermostat and opening at the right time. Antifreeze by the temp probe is way to hot, and vaporize, and the gauge spikes. After thermostat finally opens, the temp is o.k. and gauge drops. This can be due to a bad water pump, or the small hole in the thermostat body is plugged and now allowing the hot water from head area to circulate thru and warm up the thermostat. THe "oil light" is actually the over temp light coming on.
hey guys, just went over to some other forum and found out some disturbing news that ford put some kind of plastic intake on certain models of 4.6l and a coolant crossover tube can spring a leak. someone enlighten me on this. i dont want to a bunch of parts replacing i.e. water pump ,hoses ,thermostat when what i have to do is replace the intake. also read that ford had a recall on this, any truth? took the truck out yesterday and this time when the temp gauge pegged the truck actually went into power down mode and limited my power. shut the truck down for a few minutes then started back up ran normal . i have noticed my coolant is discolored and is low again but i cant find where its going. still hot and bothered!
No, unless it gets so darn hot that it breaks down the oil too thin to make pressure.
There should be a "check gauges" light when one goes out of range.
Plugg, you should be able to see it leaking if so. They all use a plastic intake, but the updated ones have an aluminum coolant crossover in the front that is easy to see.
