Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 01-25-2013, 10:02 AM
msauls msauls is offline
1958 Ford F-100
msauls is starting off with a positive reputation.
radiator support removal?
How difficult is it to remove the radiator support (only)? I can't seem to find any diagrams, or instruction?
Thanks!
  #2 (permalink)
Old 01-25-2013, 10:27 PM
tbirdscott's Avatar
tbirdscott tbirdscott is offline
Garage is empty, add now
tbirdscott is starting off with a positive reputation.
Start removing bolts till it's out. These truck come apart pretty easily. I've completely stripped two. The biggest issue is the bolts breaking due to rust, but that just means it comes apart faster!
Unbolt grill from inside fenders, remove header panel under grill, frame mounts on back side of rad support, rad, then bolts holding rad support to inner fenders. You might be able to get the rad support out without doing any more, but removing the fenders or at least one may be necessary. Never removed just the rad support before.
__________________
1960 Comet mostly stock, summer DD
1979 Ranchero/Thunderbird 'Thunchero' 390 or 460 powered in the future...
1980-82 thunderbirds everywhere you look
1994 F350 IDI turbo getting a 1959 Mercury body transplant
1994.5 F250 PSD, 5spd 4" rancho on 35's
  #3 (permalink)
Old 01-26-2013, 07:55 PM
F-100CustomCabTBC's Avatar
F-100CustomCabTBC F-100CustomCabTBC is offline
1958 Ford F-100
F-100CustomCabTBC is starting off with a positive reputation.
You will have to be a little careful I think the Radiator support is what holds the whole front end together. It is what holds up the fenders in the front which the fenders hold the grill and front valance.
You might have to try and find a way to hold the front end up. Otherwise maybe the front valance and fender skirts might help hold it up a little.
Hope that helps.
__________________
Blaine, SE MN
'58 F-100 Custom Cab short box, owned since Aug. 2006
  #4 (permalink)
Old 01-30-2013, 02:01 PM
1958 Ford F-100
Sorry, I was away for a bit!
Thanks Tbird and F100. Yeah, I think this part is a bit more integral than you'd imagine. I may have to wait to remove it until I do a full fender, etc removal.
  #5 (permalink)
Old 02-05-2013, 06:15 AM
camperspecial65 camperspecial65 is offline
camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.
fenders can stay on...remove one fender apron and loosen the other alot, remove radiator and fan/water pump pulley and you can remove it from the inside...I pulled one last year then the grille and lower valance...the grille to fender bolts are the worst...a tough nut to access..
- cs65
  #6 (permalink)
Old 02-05-2013, 02:42 PM
1958 Ford F-100
Thanks, cs65!
Quote:
  #7 (permalink)
Old 02-05-2013, 06:18 PM
Fomoko1's Avatar
Fomoko1 Fomoko1 is offline
1956 Ford F-350
Fomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputation
This is what it looks like when the front clip is removed. It`s from this thread http://www.ford-trucks.com/forums/11...ific-59-a.html thanks blackedout.
__________________
Fomoko1..Morris Chapter Leader Manitoba/Saskatchewan
56 F350 dually & 53 & 56 M100 93 F150
98 Ranger XLT S/cab 2012 F150 XLT S/cab
65/67 Mustang Fastbacks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
