Trans rebuild and other questions...
Coming up soon i'm going to be swapping engines and rebuilding my transmission. However, I'm not sure where to get parts and I haven't actually done this before.
So the questions are as follows:
Where is a good place to get a T-19 rebuild kit? I know i need bearings.
Where could I find a manual to get me started on the right path?
Edit:
I've found a few rebuild kits ranging between $100-170. Is there a way i can tell if i have the 20mm or 23mm input bearing without taking the thing apart? I'd like to have all of the parts on hand before i start.
Also, I've never had any trouble putting it in gear, but should I replace the syncros while i've got it apart? Kits with syncros cost a bit more...
Other questions:
When i put the 6.9L flywheel on the 7.3L I'm dropping in, do I need to swap the harmonic balancer as well?
Since I'm starting with the engine on the floor, what seals should I replace? I was thinking rear main, valley pan (needs one anyway), and maybe oil cooler...
If I need a complete clutch kit, where is a good place to get one, and what brands should i look for? Also, at what thickness should i replace the clutch disk? The throw-out bearing has been making noise for some time so it's getting replaced no matter what...
Are there any other tips or things i'm missing?
Thanks in advance.
Edit:
Other questions:
Thanks in advance.
If i was tearin into i would do synchros - i would not use a 6.9 flywheel on a 7.3 or vica versa - no idea on the manual, or input bearing size - for clutch if youre doing a stock replacement ive had really good luck with clutches from NAPA in various applications. - Good luck and have fun
Edit:
Thanks in advance.
Edit:
Thanks in advance.
Myself, I would not dig in that deep and not replace the baulking rings. If you need bearings, I would bet the box has enough shifts that the rings are starting to wear, too. They do more than help adjust gear speeds, they also work to hold it in gear. My T-19 is starting to need refreshing, it's been walking out of first for a while. No issue with upshifting, but now it's starting to give me bearing noise.
The 6.9 and 7.3 NA use all the same parts minus pistons, the crank is the same for all of them (including the turbo one) rods are the same for them (turbo ones are different) harmonic balancer is the same (agin different on the turbo) the 7.3 NA came with the ZF5 speed that used that dmf but your t19 will bolt up just fine and be balance, you wont have any issuses.
mark460
11-16-2018 04:00 PM
Josh S
04-08-2015 04:44 PM
SoFla64
07-10-2014 06:11 PM
wick246
68
03-15-2004 08:39 PM
