Other than taking it to the dealer, is there anyway to isolate which tire is throwing the fault? All my pressures are good and the tires are 1 year old. Nothing else has happened that would trigger a fault. 2005 Expedition EB.
Thanks
You could try a tire shop. They should have a scanner for checking that since they can change TPS valves. I suspect they'll be much less expensive than the dealer.
Took it to the tire shop and all 4 sensors are good. They reset the light and seems to be staying off, however he said there could be a problem in the TPM module.
