Cold Front
Old 01-24-2013, 06:13 PM
Cold One's Avatar
Cold One
Cold One is offline
Cold Front
Lately we have been well below zero and I am trying to find a cold/winter front for my 2011. There seems to be a lack of these products on the market and was wondering if any of you have one or do I need to take the time to fab one. I have a 4 month old that will love the quicker warm ups in the morning. We thank you for your help in advance!
Old 01-25-2013, 12:42 AM
Marching Ant's Avatar
Marching Ant
Marching Ant is offline
I have a cold front from a company called Fia. A quick internet search will turn up a few online retailers. Mine came with a both a winter front and a summer front (bug screen) which mount on the same studs. Fia uses plastic stick-a-stud fasteners which use adhesive to stick to the grille. The advantage here is an easier install and you can remove them without a trace.
The only alternative I found was from Alaska Tent and Tarp. They will also include a summer front if you ask (and pay extra). Their model attaches with metal studs which screw into the grille. The advantage is obviously strength, but you will be drilling holes in your grille.
The AK Tent and Tarp model was going to cost over twice as much as the Fia - but I do believe it is of higher quality.
I think there was someone who retrofitted an older Ford brand to fit, search the forums for more info on that.
MA
Old 01-25-2013, 01:04 PM
los341's Avatar
los341
los341 is offline
Your title led me to believe you were going to talk about the weather. As if you were hoping for a cold front to pass you by.
Old 01-25-2013, 05:39 PM
screwy's Avatar
screwy
screwy is offline
Old 01-25-2013, 05:55 PM
2012F250SUPERDUTY4X4's Avatar
2012F250SUPERDUTY4X4 is offline
There should be one made from clear polycarbonate that just goes over the stock grill.
Time to do some molding.
Old 01-25-2013, 10:48 PM
fudge89's Avatar
fudge89
fudge89 is offline
I installed the FORD winter front from a 2010 Super duty on my 2012 F250 Lariat. It fits great.. you just need to modify the lower tabs and secure them with mini bungee cords inside the bumper.
Old 01-26-2013, 07:09 AM
SavageNFS's Avatar
SavageNFS
SavageNFS is online now
Received 7,017 Likes on 2,200 Posts
Welcome to FTE! Would you mind posting a picture of your install?
Old 01-26-2013, 10:49 AM
TRENT310's Avatar
TRENT310
TRENT310 is offline
Cardboard or plastic slid between the radiators works and then you don't see anything on the outside.
Old 01-28-2013, 08:47 PM
Cold One's Avatar
Cold One
Cold One is offline
screwy I saw your post and thought it looked great. I was thinking of using aluminum and doing something similar.
fudge89 I would like to see the fit on yours also if you could post pics. Is there a gap on any of the sides?
Old 01-28-2013, 09:50 PM
madsonp's Avatar
madsonp
madsonp is offline
Here in Montana we just stick a piece of cardboard in front of our radiators, cheap and easy, then you throw it away when it warms up.
Old 01-29-2013, 11:34 AM
ggadwa's Avatar
ggadwa
ggadwa is offline
I live in Stanley IDAHO often the coldest spot in the Lower 48. I have always been perfectly happy with FREE Cardboard in front of the Radiator on my various FORDS.
GARY
Old 01-30-2013, 09:59 AM
jfritz_drfritz's Avatar
jfritz_drfritz
jfritz_drfritz is offline
So I will be the devils advocate here and say I cannot understand the utility of a cold front cover for these trucks. There is a thermostat that regulates your water temp and unless it fails how can blocking the air to the rad make a difference? It was -35C here this morning and driving in on the highway engine oil temp and transmission temp were entirely normal (same as they are in the summer). So unless you are concerned about a rock in the radiator what is the point??
Old 01-30-2013, 10:07 AM
jdadamsjr's Avatar
jdadamsjr
jdadamsjr is offline
Wind chill when moving makes for less 'work' to overcome the initial warmup...
Old 01-30-2013, 11:13 AM
marchare011's Avatar
marchare011
marchare011 is offline
Blocking off or reducing the air flow thru the radiator facilitates quicker warm-ups, which helps the cabin temperature maintain a more desirable comfort level even while idling, and improves engine efficiency and fuel economy by running the engine at a warmer temp. That's why OTR trucks use shutters on the grille. These are of course my opinions and real world experience based solely on 40 years of driving and working around diesel engines in cold climates. No scientific experiments were performed to come up with this opinion.
I also use the cardboard during extended low temps of 0 or colder.
Old 01-30-2013, 01:32 PM
jfritz_drfritz
I understand that is the conventional wisdom, but my question is that if the water for the heater core is drawn from the block and the thermostat is closed when the engine is below operating temperature, why would changing the temperature of the coolant in the radiator which is not circulating make a difference in warmup time? Is it because it reduces air circulation around the engine block and this reduces cooling? I have never been able to understand this.
Quick Reply: Cold Front
