Transmission and Motor mounts 56 Ford F-100 - Ford Truck Enthusiasts Forums
Old 01-24-2013, 11:01 AM
Outlaw56 Outlaw56 is offline
Outlaw56 is gaining momentum as a positive member of FTE.Outlaw56 is gaining momentum as a positive member of FTE.
Anyone have any experience mounting a 292 Y-Block with an AOD transmission to a 56 Ford F-100 stock frame? Its approximately 50" from the front motor mount to the rear transission mount. Some of the stock Y-Blocks and automatic transmission were mounted at the front of the motor and the rear of the tranny tailshaft with a set of "stabilizer" rod on each side of the engine block to the frame. Im thinking I need something in the area of the transmission to engine block area to help support the engine and transmission. The stablizier rods used in thrunderbirds andd mustangs might be a little too light to provide adequate support.
Old 01-24-2013, 11:29 AM
jim collins jim collins is offline
jim collins has a good reputation on FTE.jim collins has a good reputation on FTE.jim collins has a good reputation on FTE.
If i were doing it i would get a custom or even universal cross member that went from frame rail to frame rail underneath the engine to make use of the side motor mounts. Then get an adjustable one for under the rear of the AOD trany. Just place the engine on it and move it forward or back to where radiator , exhuast ect. all fit , then secure it in place. You can get the crossmembers at a lot of places like speedway auto ect.
Old 01-25-2013, 09:04 PM
I got the AOD mounted to the Y block and installed the engine/tranny and cab today. With just the stock front motor mount and the custom cross member at the rear of the AOD, the engine is too unstable. I had originally planned on using stock thunderbird stabilizer rods running from each side of the engine block to the frame rails. I am now convinced thats not a good option. I will plan on using custom mounts to secure engine to frame rails or fabricated cross member frame rail to frame rail. Thanks for your advise.
Old 01-26-2013, 10:32 AM
Not only is it unstable but it puts to must stress on the area where the trany is bolted to the engine, it will break loose . How do i know ? Been there and done that with a chevy 350 motor mounts in front and trany mount at the end of the tail shaft housing. I was lucky i saw the cracking when it was parked not when i was driving it. I was trying to fit the engine in a vehical that had the steering gear in the way of the side mounts. Junked that project.
Old 01-26-2013, 10:48 AM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
Drag cars will use engine mount plates in front of and behind the engine block. You could probably work up something like this between the engine and trans to create your own stable mid mount to work in conjunction with your existing ones.
56 F-100 with AOD Outlaw56 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 09-28-2016 03:14 AM
Front Sump Oil Pan 55 F100 Stock Steering (w Toyota PS). johnson.jeff.a 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 10-20-2015 05:34 PM
500 CID Lincoln Y-block for '53-'56 F100 gary534 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 18 04-26-2014 08:38 PM
f600 engine swap help needed fat otis 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 04-19-2014 04:22 PM
Mounting B Block 56 Ford F-100 Outlaw56 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 01-31-2013 10:52 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
