79 f250 4x4 - Ford Truck Enthusiasts Forums
79 f250 4x4
Old 01-24-2013, 09:34 AM
Quacka Quacka is offline
Quacka is starting off with a positive reputation.
79 f250 4x4
i found a 79 f250 4x4 with a 4spd inline 6 for $1500. minimal rust. seat has built-in head rest. so i am guessing the seat is not original? i havent looked at it yet, but plan on a test drive in the next day or so. from what i can read online, the 6 is a great motor, but just not a speed demon. is this as good of a deal as i think it is? that is all the info i have right now. thanks for the input.
also, if you could give me some tips or pointers to look for when i do take a look at it, it would be appreciated.
jason
edit: it has a bull bar or push bar on the front. was this option available in 79? it is black with 2 horizontal round tubes.
Old 01-24-2013, 12:41 PM
77&79F250's Avatar
77&79F250 77&79F250 is online now
Used OEM parts guy
77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future
Not bad price for a 4x4 F250, yea 6 cly is dependable and torquey, just not much in the way of top end.
Seat sounds like a swap in, does it have a fold out arm rest by chance?
Insp the front cab mounts for rust and ck the steering box for excessive play. Make sure the transfer case/4x4 works also.
If it is stock and no lift and big tires it should be in good shape mechanical shape.
Oh yea forgot to mention the push bar is worth $$$$
Old 01-24-2013, 12:50 PM
montana_highboy montana_highboy is offline
montana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud of
Quote:
The factory push bars an easy $300 on ebay (don't tell the seller ), a running and functioning 4x4 with minimal rust is almost always worth at least $1,500 in my book.
Old 01-24-2013, 01:02 PM
new info:
i still have not actually seen the truck, in person, because the guy is slow to email me back, but i did notice in the picture that the bed doesnt match the truck. the bed is from a 73-75 model as it has trim all the way across the bottom. i think the bed was the same from 73-79, just different trim options from year to year. here is a link:
79 f250 4x4 - $1500 (sandston)
Old 01-24-2013, 01:22 PM
77&79F250's Avatar
Used OEM parts guy
That looks to be worth it, the push bar is not OEM but still they are hard to find.
The bed is a swap on from a 73 to 76 cause it has the exposed gas cap and not a 77-79 gas flap.
You can pull the front fender and cab "dent" chrome strip and the botton chrome off the bed and do a little body work to get it to match up.
Or add the chrome to the bed "dent" and add it to the botton of the fender and cab??
79 F150 4x4 Sway Bar Bushings hurst1979olds 1973 - 1979 F-100 & Larger F-Series Trucks 3 04-07-2016 10:58 AM
78-79 Front Dana 60 Sway Bar Links ss74nova 1973 - 1979 F-100 & Larger F-Series Trucks 15 03-08-2016 09:21 AM
1963 F250 Bench Seat and Bracket Bolt Pattern wcs69rat 1961 - 1966 F-100 & Larger F-Series Trucks 0 01-27-2016 09:29 PM
77.5-79 Dana 44 f250 front sway bar and links crazed87bronco Ford Truck Parts for Sale 1 11-28-2015 09:21 PM
Anybody Running Fender Well Headers on 78/79 F250 4X4 w/Front Sway Bar? twinzilla 1973 - 1979 F-100 & Larger F-Series Trucks 4 06-19-2014 08:42 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
