Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 01-24-2013, 02:38 AM
mtdorf mtdorf is offline
Garage is empty, add now
mtdorf is starting off with a positive reputation.
Modified gas tank???
Ok, I want to get rid of the behind the seat fuel tank in my 59 f100 as i'm tired of smelling the gas and I want to have that little extra room for my long legs and bigger belly. I want your advice/opinions and expertise on how to go about mounting another fuel tank. I have a couple of side tanks from various year f150s and 250s. I also have a friend who said he can fabricate one to fit within the frame just under the bed and would hold upwards of 50 gallons of fuel.
So anyone who has done this please chime in as I need the advice and knowledge.
Thanks
  #2 (permalink)
Old 01-24-2013, 04:55 AM
Walston's Avatar
Walston Walston is offline
1960 Ford F-100
Walston has a good reputation on FTE.Walston has a good reputation on FTE.Walston has a good reputation on FTE.
There are pictures in my gallery. I used a 1969 mustang tank. My fill tube is located behind the license plate.
__________________
Walston
http://bigjohnstractor.com/
  #3 (permalink)
Old 01-24-2013, 10:36 AM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
theodore/teddy is starting off with a positive reputation.
I put a Rodeo 22 gal tank behind the rear axle between the frame rails, with the filler through the rear quarter panel.
50 gallons of fuel takes a considerable amount of space.
Good luck in your quest!
__________________
Looking for an in bed spare tire mount for styleside fridge bed.
1959 F250 4x4
Wally
  #4 (permalink)
Old 01-24-2013, 02:25 PM
ibuzzard's Avatar
ibuzzard ibuzzard is online now
We'll Always Have Poway..
ibuzzard has a very good reputation on FTE.ibuzzard has a very good reputation on FTE.ibuzzard has a very good reputation on FTE.ibuzzard has a very good reputation on FTE.
I believe that simply removing the tank, in and of itself, will not give much if any additional room to adjust a stock seat backwards. You would, I believe, have to either change seats, or relocate the mounting holes or rails. Even then, the stock seat would need to be adjusted to almost straight up, or perpendicular to gain much. The greatest gain would come from using a different steering column to move the wheel closer to the dash.
You could always remove a six inch section of your femurs, and notch the steering wheel to accommodate your belly, might be cheaper.LOL!
__________________
"Why, yes, I have plenty of spare change, you worthless piece of crap."
'59 F250 w/an Engine, a Transmission, Some Tires/Wheels, PLUS-a Genuine Radio
" Show me your Tee-Hee, I'll show you mine."
  #5 (permalink)
Old 01-24-2013, 03:26 PM
i have been trying to figure out a way to remove the six inches of extra gut...seems that most conventional fabrications require some sort of medical background LMAO!!
Thanks to all who replied, if I'm successful I will post pics.
  #6 (permalink)
Old 01-24-2013, 05:36 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
Here's some reading for you along this line of thought before you cut yor legs off! INSTALLING A MID-60's Mustang Tank in a '53 F-100 truck
  #7 (permalink)
Old 01-24-2013, 07:07 PM
ibuzzard's Avatar
Mtdorf, I am 5'9". Our era trucks are admittedly short on legroom. With my seat all the way back, which I need to do also, the top of the backrest is touching the rear of the cab, so it cannot go back any further, no matter if the tank is there or not. Perhaps if I moved the stops in, I could gain an inch and a half, but my seat would be uncomfortably upright. Perhaps different seat may gain you something, but I do not know.
By the way, my stomach has never been described s minuscule, either.
Steve
__________________
  #8 (permalink)
Old 01-24-2013, 08:52 PM
economan economan is offline
economan is starting off with a positive reputation.
switch over to a 57-60 panel bodied truck then you will have upwards of 6 feet to move the seat back (heh heh)
mikie
near ottawa canada
58 m-100 panel, 64 econo p/u
  #9 (permalink)
Old 01-25-2013, 08:16 PM
My wife says i just need to fabricate an extra cab, that way i'll fit and all my toys can go with me on my trips...she is tired of holding the rifles when we travel!!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
