My tires do the splits
I have a 1995 F250 single cab, long bed truck with 37" tires and a 6" lift. It has a 460 big block engine after market exhaust and twin I beam suspension. My passenger side front tire is wearing faster than all the others and is almost bald in the center the edges still have tread though. When I back up my front tires tilt inward and its very noticeable! It looks something like this /-\ I'm not sure what's wrong? Or what I need to do to fix the problem. New tire rods maybe?
Usually tire wear with tread gone in the middle and good tread on sides indicates over inflation, worn sides and good tread in the middle usually indicates under inflation.
Tell us something about your 37" tires and what the rim width is.
I ran 50 psi in my stock size tires on the stock rims in the name of fuel efficiency. And yep sure enough the center of the tread wore faster than the edges.
I would still check all the parts, but I've always noticed the twin-traction beam trucks will have the front wheels looking like /-\ after backing up. My truck does it slightly, bone stock with sway bar, my mother's truck does it more noticeably (no sway, also stock).
The left front wearing faster than the right front is what sounds most suspect to me. Does the truck pull way one or another?
What you have is twin traction beam it's same concept as twin I beam. Had it on my old F250 I thought I'd poke around the early 90s thread since I haven't been here since I sold it and now I'm having flashbacks. It's a common problem on ttb trucks especially once you lift them I had to look around to find a shop that would do a camber alignment for me it's tricky with the way you have to do it with bushings. Before you take it in jack up the front end a start trying to shake stuff with the wheel off the ground put a pry bar under the front wheel if you can shake it up and down separate from the suspension it's a ball joint but as I said I suspect you just need an alignment
+1 on that. All my Ford trucks do/did it. Just how it is with the front end setup. Not like anyone drives for miles in reverse too often, so tire wear ain't an issue here. If your tires are wearing, it's from something being out of line while driving forward.
Im running my front tires @ 50 psi. They're not over inflated nor under inflated, my truck does pull to the right though while driving.
