Bronco II Ford Bronco II
Reverse light wiring
Old 01-23-2013, 01:26 PM
chollyb's Avatar
chollyb
chollyb is offline
I have a 84 Bronco II. There is a wire hanging down that is not connected. I think it's for my reverse lights. I think it is supposed to be connected to the transmission. Can anyone tell me where it connects to the transmission?
Thanks
Old 01-25-2013, 11:38 PM
Rangerman Stan's Avatar
Rangerman Stan
Rangerman Stan is offline
There is a switch on the side of the tranny that has either two round plug type connectors or two blade connectors on it that is the back up light switch. There should be two wires going to the switch, so if you find one wire going to the tranny follow it to where it plugs in and see if it should have a second wire there too with the connector. The switch could be on the back of the tranny case too so check all around it.
BlueOx460
03-29-2017 07:17 PM
davidwjacob
07-23-2014 01:57 PM
Rollin.IH.Coal
15
11-04-2011 10:28 AM
pepsiguy
Large Truck
09-14-2011 06:50 PM
Lifted94XLT
Kansas Chapter
18
03-09-2004 11:39 PM
Quick Reply: Reverse light wiring
