Engine cranks, turns and then dies - Ford Truck Enthusiasts Forums
Modular V10 (6.8l) SPONSORED BY:
Old 01-23-2013, 12:51 PM
myblkex's Avatar
myblkex myblkex is offline
myblkex is gaining momentum as a positive member of FTE.
Strange issue --
I also tried jump starting - get same same result. Engine cranks, turns, and then sounds like it is just about to start up normally but it just dies completely. It seems to want to start but just can accelerate the engine high enough to keep it running. Almost like it's flooded on a carb motor.. anyone have ideas ??
2000 V10
Old 01-23-2013, 03:39 PM
myblkex's Avatar
Got back home and this time I held the accelerator down when it started turning and it puffed and stumbled - but it started ! Now I need to see why I need to slam on the accelerator in order to get it to not die when it tries to start ....
Old 01-23-2013, 04:06 PM
jh818's Avatar
jh818 jh818 is offline
jh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputation
IAC valve. Answered you in the Excursion forum.
Help/advise 2006 F250 5.4L no start no codes BantyRooster 1999 to 2016 Super Duty 9 01-05-2016 04:32 PM
Help/advise 2006 F250 5.4L no start no codes BantyRooster Performance & General Engine Building 8 01-02-2016 04:01 PM
94 F350 5.8 dies while driving AndyBaggett Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 06-08-2015 10:51 AM
Truck just died ccrispin 1999 to 2016 Super Duty 5 07-28-2014 02:45 PM
Replaced t-stat, now won't start Number21 6.0L Power Stroke Diesel 102 03-12-2014 07:01 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
