Go Back   Ford Truck Enthusiasts Forums > Marketplace > Want to Buy > WTB - Parts & other
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
WTB - Parts & other Want to buy parts/accessories/tools.
  #1 (permalink)
Old 01-23-2013, 11:32 AM
batchman batchman is offline
Garage is empty, add now
batchman is starting off with a positive reputation.
2wd e4od rear drive shaft front half 30"
I seek the front portion of the rear drive shaft measuring more than 32" from u-joint center to the neck-down at the carrier bearing.
Believe this would be found in an 89-up crew cab long bed 2wd with e4od.
If I can't find this I'll try to find the 36" version as found on a CC/LB with a c6 and shorten it.
Thanks for any leads,
- Jeff
__________________
Old and Busted: 1-owner 84 Bronco modded 351W, 33's featuring rockers held up by seatbelts.
New Hotness: 86 CCLB DRW Banks IDI C6 4L10.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
