4R44e Trans issues
Old 01-23-2013, 09:28 AM
JDpuller4010's Avatar
JDpuller4010
JDpuller4010 is offline
4R44e Trans issues
I've got an 98 Ranger 2WD with a 4R44e. The problem I have is when it shifts from third to OD, it acts like something is slipping. I have had the transmission out at 150K when the reverse band broke. Replaced the forward clutches and all the bands in it. also replaced the valve body gasket, since it was blown out. had a Ford dealer update the valve body. I have changed the trans fluid with the recommended intervals. The truck has 217k on it now. Any suggestions or ideas would be appreciated.
Old 01-23-2013, 10:32 AM
KhanTyranitar's Avatar
KhanTyranitar
KhanTyranitar is offline
What is your maintenance history?
Old 01-23-2013, 11:09 AM
pawpaw's Avatar
pawpaw
pawpaw is offline
Welcome to FTE.
Have a trusted tranny shop scan the Tranny Computer for trouble codes & post All code Numbers found, as they can offer up good trouble shooting clues.
Old 01-23-2013, 11:51 AM
JDpuller4010
maintenace schedule is every 35-40K fluid is red and not burnt
JDpuller4010
There is no check engine lights on and i have a code reader no codes for trans
Old 01-23-2013, 01:28 PM
pawpaw's Avatar
pawpaw
pawpaw is offline
OK, good feedback on their not being any CEL lit for the engine computer. Still could be "pending" codes stored, that haven't happened often, or long enough for the engine computer to get aggrivated enough & turn the CEL on yet.
The tranny computer requires a special scantool to extract its trouble codes, so a code reader can't read them & is why I suggested having a trusted tranny shop do it.
During any of the tranny shifting fits, has the OD light blinked????
Old 01-24-2013, 06:22 AM
g_k50's Avatar
g_k50
g_k50 is offline
the cheap and short term solution is to run the truck in Drive, not overdrive.
Shift to overdrive when at highway speeds, use Drive to accelerate up to highway speeds.
Old 01-24-2013, 09:28 AM
JDpuller4010
no od lights come on it seems to me that maybe a sensor is acting up sometimes it shifts extremely hard and the rpms come up then the trans shifts. Ive have replaced the abs sensor and thinking it might be either a trans shift solenoid, actuator, or range sensor.
Old 02-11-2014, 09:12 AM
JDpuller4010
My 4r44e trans which has cruize control, when i set it it sometimes kicks out of cruize. My foot is no where near the brake pedal. i have a new abs sensor and also abs connector on it. any suggestions.
ChrisInFlatMO
06-08-2018 11:08 AM
TJVJR
10-22-2015 09:11 AM
carsmars
10-12-2009 09:43 PM
madredneck
05-15-2008 08:08 AM
mtnman01
05-15-2007 09:17 AM
Quick Reply: 4R44e Trans issues
