You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I done the servicing on the Hubs & Wheel Bearings of a mate's 2002 F-250 XL 4.2Ltr 4X4.
However I noticed as soon as I pulled the first wheel that there was no cable going to the ABS??
I went round a checked the other side; same story??
However when I removed the caliper and pulled the Rotor Disc off, the actual sensor was in place on both sides.
The electrical cables had simply been snipped off at the sensor. No sign of any cable being there (no old cable hanging from up under the fender or bay).
The mate said it had been that way from when he bought it from the PO.
It's done 330K km and he has never noticed any issues with braking.
No ABS trouble light comes up.
Would this have been how these XL 4.2 trucks came form factory or has the PO simply cut them off .
I guess I'm asking; Did the lower spec XL models come with ABS.
Those with these XL 4.2 trucks should be able to answer this.
Anyway I pulled the ABS Sensor out and used the RiffRaff fitting to pump grease into his wheel bearings and do the servicing.
If thse don't have ABS then I intend to permanently fit greasing Zerks in there for him.
Cheers,
Reg
__________________ Aussie spec 2005 (US 2003) F-250 SD 4x4 7.3Ltr Powerstroke: PHP FU2 6 Pos’n Chip,6 x ISSPRO Guages, AIS Intake, Zoodad, Hutch'd n’ Harpoon'd. Cowl Hood, AIH Delete, CCV, RiffRaff FRx,HPx,OCR, JWVB. ARB Air Lockers Front & Rear,V10 Tranny cooler + Stock Tranny cooler, ARB Bull Bar. Long Range Fuel Tank,VMS in Dash GPS Nav.OME Suspension & Dual Tower Shocks, MOOG Ball Joints. GVWR (GVM) Upgrade to 5,000Kg (F350+).
Abs on all the 4.2l was only fitted to the rear axle (same single sensor above the crown wheel as the 7.3)
The sensors were fitted to the axle on the front (as you found) but that was it.
__________________
Adrian | 2005 4x4 Diesel Ranger CrewCab in Aus | 2000 4x4 SC/LB F350 7.3 ZF-6 in the US
G'day Adrian,
Thanks for that M8. I thought as much.
I'll knock up a couple of zerks to fit and run a short braided line to make it a simple greasing routine for him next time I'm due to service his wheel bearings.
This will save having to remove the calipers and rotor from then on.
Cheers,
Reg
You've made virtue out of necessity there Reg, well done!
__________________
Mods done: lots of cheap mods (Hutch, IC boots, plenum inserts, IH uppies, HPx, AIH delete, EBPV delete, hi flow outlet, CCV mod, OCR, Superchips, Zoodad, 6637, 4" TB exhaust, JW valvebody, coolant filter, FRx, '05 HD lights with switch bypass relays, B100 ready fuel system)
Mods NOT done: big oil, big brakes, big turbo
Next mods: ? tuner, G2WW (on the shelf), alloy diff covers
Australia: where Mechanics use spanners and Plumbers use wrenches...
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
