You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Anybody disabled the traction control? I've had the truck for 22k miles and just noticed the TC button. So I turned it off just to see if I would notice a difference and guess what? I did. I get a lot of wheel spin( gravel or not) and my MPG went up by 1 MPG. Amazing.
I'm gonna leave it disabled for a week to see if the improved MPG holds up. Wish me luck.
__________________
2012 F-350 Chassis Cab,12-ft flatbed,6.2 gas
X-PSD driver, done with diesels
Don't you have to disable it every time you start the truck? Or can you shut it off for good?
__________________
Kevin
2011 F-250 CC, 6.2 Gas, 3.73, 4x4 w/FX4, Tuxedo Black, Steel Cloth interior,Goodyear Wrangler Duratrac's, Air Aid Intake, Bilstein 5100 shocks, Hellwig adjustable sway bar, 5 Star Tuned, Line X bed liner, X Tang Tri-Fold bed cover.
i'm pretty sure he is going to be stuck pushing the button every time he starts the truck, according to experience and the user manual.
remember, there are also different settings you change, depending on how long you press the 'traction control' button. briefly pressing it will just turn of traction control. holding the button for a few seconds with also turn of 'Electronic Stability Control' and 'Roll Stability Control'. If you are traveling over 35mph, the ESC and RSC will automatically re-engage, leaving only TCS as being off.
__________________
2011 F-250 CC - 6.2L, 4x4, 3.73, Lariat Ultimate Pkg, ReadyLift 3.5"Fx3.0"R lift kit, 35x11.5x18 Terra Grapplers
'Capital Campers', give your go some show
I thought the option was in the settings menu on the LCD screen.
__________________
Kevin
The LCD screen will just display if TCS is on or off. You can't control it from there. I'm also pretty sure that the LCD screen displays nothing about ESC or RSC being on or off, but the user manual explains it. I have also tested out the ESC being off versus just having the TCS off.
You can tell a difference on a gravel road. With just TCS off, you will still maintain positive traction, leaving 2 peel out marks (the best setting for going offroad). With ESC turned off, your truck will act like a true open differential, leaving 1 peel out mark (I see no practical purpose for turning this off).
__________________
Your correct, I checked it out on mine after work. My wife's Explorer you have to turn it off through the LCD screen menu. That must have been what I was thinking about, I did see my button on the dash.
__________________
Kevin
I don't think my chassis cab has anti-roll or stability control since it is a dually. I am still seeing improved mpg today, up to 13.6 mpg.
Not bad for a one ton flatbed truck with a reliable gas motor.
__________________
Holding the button until the AdvanceTrac off message is displayed and disabling the RSC/ESC is helpful when you are laying on the frame in the mud and trying to get pulled out. When all 4 tires start spinning even in 4LO that system will kick in and try to make them stop slipping by cutting power way back.
I had this happen to me. I couldn't figure out why my truck seemed to be stumbling while trying to get out. The Lower Control Arms on the front axle were hooked in the ground good and when the tires started slipping the AdvanceTrac system cut my power and I stopped dead. Took one hell of a tug to get me out. Once I turned off TCS/AdvanceTrac the truck would finally let me have full power in 4LO to help climb my way out of the holes I had dug my self into.
I will also add that I have an E-Locker so I had had 3 tires digging when I was trying to get through.
when I put my truck in 4lo, I get a message that says advancetrac off.
Agreed, it say in the operating manual that when in 4Lo, all TCS, ESC, and RSC are automatically turned off. In 4Hi or 2wd they remain on until turned off.
__________________
