oil life reset
oil life reset
Just changed the oil (new to me used 2011) and went to reset oil life and it won't change from 26%, reset on another menu to 100% but the oil life won't go to 100% what gives?? Another question... going to change coolant tomorrow, didn't really look around while I was under the truck. I assume theres a drain valve on the radiator to drain it and afterwards fill with about 6 gallons through the expansion tank? I'm in the process of changing all of the fluids so I know where I'm at being that its a used truck with high milage
How many miles do you have on the truck?
Maybe you don't have an owners manual with all the explanations of the truck, you can also goggle to find a owners manual and download it. Here you go. http://justgivemethedamnmanual.com/f...owners-manuals
2012 F-250/350/450/550 (f23)
Owners Guide, 4th Printing USA (fus)
Instrument Cluster
System check and vehicle feature customization
Press the SETUP button repeatedly to cycle the message center through the following features:
Note: Some items are optional and will not appear.
Note: When returning to the SETUP menu and a non-English language has been selected, HOLD
RESET FOR ENGLISH will be displayed to change back to English. Press and hold the RESET button to
RESET FOR SYSTEM CHECK
When this message appears, press the RESET button and the message center will begin to cycle
through the following systems and provide a status of the item if needed.
1. OIL LIFE
2. EXHAUST FLUID LEVEL (Diesel only)
3. ENGINE HOURS
4. ENGINE IDLE HOURS
5. CHARGING SYSTEM
6. DOOR
7. BRAKE SYSTEM
8. TBC GAIN = XX.X (if equipped)
9. FUEL LEVEL
10. MYKEY DISTANCE (if MyKey® is programmed)
11. MYKEY(S) PROGRAMMED
12. ADMIN KEYS PROGRAMMED
Note: Some systems show a message only if a condition is present.
OIL LIFE
This displays the remaining oil life.
An oil change is required whenever indicated by the message center and according to the recommended
maintenance schedule.
To reset the oil monitoring system to 100% after each oil change, perform the following:
1. Press and release the SETUP button to display “OIL LIFE XXX% HOLD RESET = NEW”.
2. Press and hold the RESET button for two seconds and release to reset the oil life to 100%.
Note: To change oil life 100% value (if equipped with this feature) to another value, proceed to
Step 3.
3. Once “OIL LIFE SET TO XXX%” is displayed, release and press the RESET button to change the oil
life start value. Each release and press will reduce the value by 10%.
Instrument Cluster
1. OIL LIFE
3. ENGINE HOURS
5. CHARGING SYSTEM
6. DOOR
7. BRAKE SYSTEM
9. FUEL LEVEL
OIL LIFE
Step 3.
Did my first oil change last weekend. (Mobil1) Afterwards, I went into the dashboard menu to reset the oil life, and it had automatically reset itself to 100%. I was a bit perplexed as I didn't think the truck was smart enough to know that the oil & filter had been changed.
Also installed a Fumoto valve to make future oil changes easier
Yep. Thanks. I actually did it last night after getting close to the 1500 number. Changed with with Motorcraft this time, since I will be changing it at 5k, and at that point going forward I plan on running Red Line Full Synthetic. I've run it in the Mustang since I got it with 16k miles and at 70k it has perfect compression across the board.
