1977 F-100 "ClifFORD" Crown Vic swap - Ford Truck Enthusiasts Forums
Old 01-22-2013, 09:31 PM
SkinnyPedal's Avatar
SkinnyPedal SkinnyPedal is offline
SkinnyPedal is starting off with a positive reputation.
We have a 77 F-100 our plans are to do the crown vic swap w/4.6, F/R susp, disk all around, and lowered 5". This will be our 1st ford project. We have alot to learn, so any and all input will be appreciated.
Thanks
Old 01-22-2013, 10:55 PM
davewild's Avatar
davewild davewild is offline
davewild is starting off with a positive reputation.
I host my pictures on photo bucket or the like. It's the easiest route to go. Can't wait to see the progress!
Old 01-23-2013, 09:07 AM
Thanks dave
Stock power plant 302 w/C-4 auto. Also for sale
Old 01-25-2013, 10:41 PM
The Donor; 1999 wit 93xxx on the clock. Still need to find a 03 up subframe.
The rear axle has disk wit 3:27 gear limited slip. Could someone tell me if there is any reasons I couldn't us it?
Old 01-26-2013, 12:47 AM
bighatchy bighatchy is offline
bighatchy is starting off with a positive reputation.
Are you going to keep that sweet patinad look its got going? This going to be a great build
Old 01-26-2013, 08:11 AM
BigBlockMan's Avatar
BigBlockMan BigBlockMan is offline
BigBlockMan is starting off with a positive reputation.
On the 73' to 79' trucks if you had bought a Towncar the wheel base would have been the same. For the 67'-72' trucks the Crown Vic's have the same wheel base. Then you just swap bodies and that's it. You have a F100 with a 4.6l pwr steering, A/c, 4 wheel disc brakes and it's lowered. Factory ride height for a CV but about 6" lower than an F100. 25 mpg too. To make the 4.6l run it is easier to use a keyless entry car. Good-Luck.
Old 01-26-2013, 09:49 AM
jim collins jim collins is offline
jim collins has a good reputation on FTE.jim collins has a good reputation on FTE.jim collins has a good reputation on FTE.
Quote:
Have you seen that body swap done or is that just an idea ? I hear all kinds of ideas, but some facts would be helpful . Body swap like that is some thing i might want to do.
Old 01-26-2013, 10:29 PM
My uncle has done 3 of the 67'-72' truck's. And is starting the 4th on Monday. We have taken measurements on the 73'-79' truck's. I have a 73' that we will be doing a 03' and up CV crossmember swap. I'm more into the 48'-56' truck's. I hang out at his shop a good bit. You ever have too many plans, with too many car's and not enough money? That's me.
Old 01-26-2013, 11:41 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Nope..' just short on daylight. I can't wait for Sunday, March 10 when we spring forward!!!
Old 01-27-2013, 03:26 PM
Quote:
Thats the plan thus far but you know how plans go. LOL
Old 01-27-2013, 03:29 PM
Thanks for the info.
Old 01-31-2013, 08:21 PM
Picked up a 04 crown vic subframe today. The CV frame rails are still attached, lol but it was CHEAP.
Old 04-06-2013, 10:26 PM
Question HELP !!
they are mounting the CV subframe. Got to the point where welding the lower control arms rear mounts on but not sure how to line the up.? Moving the rear of the lower control arm in or out changes the camber/caster (ball joint angle) so how do you know where to weld the mounts?
Cut the spacers/tubes out of the CV frame and used a 1.5" hole saw and droped the original CV spacers in place and welded them in. Just like factory did on the CV.
Old 04-06-2013, 10:50 PM
CV Lower Control arm ???
We have drawed a line in the pic to show the alignment in question?
Lower control arm brackets.
Old 04-07-2013, 10:46 AM
GM4WALLS's Avatar
GM4WALLS GM4WALLS is offline
GM4WALLS is gaining momentum as a positive member of FTE.GM4WALLS is gaining momentum as a positive member of FTE.
Subscribed.
test johnchesley Testing..... 2 02-15-2013 12:06 PM
Evolution of "The Mistress" Brown Falcon Oregon Chapter 11 12-30-2011 12:02 AM
picture test harrisford User Gallery & Picture Display 3 07-16-2011 09:09 PM
Indiana truck pics cowmilker08 Indiana Chapter 2 04-14-2009 03:56 PM
Any idea what motor this might be? Jeff3298 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 17 07-23-2008 09:49 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
