1977 F-100 "ClifFORD" Crown Vic swap
Old 04-11-2014, 11:49 PM
Blue Oval Farm Boy's Avatar
Blue Oval Farm Boy
Blue Oval Farm Boy is offline
What he was saying is the 02 and older does not have the removable front suspension so that is not what you want. What you want to use is the 03 -04 front suspension as it bolts to the cv frame, hence it will bolt to the truck frame. The 05 and up suspension will also work but if you use the engine there will be more wiring than the older cv.
  #77
Old 04-12-2014, 01:33 AM
blue04.5's Avatar
blue04.5
blue04.5 is offline
There is another guy that drops the pick up body on the older crown vics frame, just like my previous post says, pull the car body off and put the truck body on.
  #78
Old 12-06-2014, 02:41 PM
Ottawavalleylad's Avatar
Ottawavalleylad
Ottawavalleylad is offline
This Clifford build is pretty motivating! What a beautiful truck.
SkinnyPedal, were you able to use the crown vic driveshaft? Also, did you use lowering springs on the front? You have a perfect stance!
  #79
Old 12-07-2014, 07:41 PM
loudfords's Avatar
loudfords
loudfords is offline
Thanks for this thread. Due to this thread and others, I'm in the hunt for a Crown Vic right now to convert my truck...
  #80
Old 02-20-2015, 09:02 PM
Bigfreeb's Avatar
Bigfreeb
Bigfreeb is offline
I know this thread is old!!! Skinny pedal you still out there? I have the CV front suspension from an '04 and I just got a line on a motor, trans, wiring, PCM, rear diff and drive shaft from a '02 for $400. In one of your posts you say buying the wiring harness would be easier. Would it be easier to use the Ron Francis kit for just short of $1000? Hope the truck is still doing good! Its an inspiration to many.
  #81
Old 09-03-2015, 11:44 AM
SkinnyPedal's Avatar
SkinnyPedal
SkinnyPedal is offline
I cut a round and half off of the OE vic springs up front. and I did use the vic's drive-shaft. I did have to install a spacer from Summit.
Sry all,
Been awhile since I been on here. I will try and check in here more often now.
  #82
Old 09-03-2015, 11:49 AM
SkinnyPedal
Doing the wiring yourself in a lot cheaper but purchase one is a lot quicker and easier.
  #83
Old 10-22-2015, 07:06 PM
loudfords's Avatar
loudfords
Originally Posted by SkinnyPedal
We have drawed a line in the pic to show the alignment in question?
What did you find the dimension between the rear mounts of the lower A-arms to be? I'm not 100% sure the measurement on my donor car is correct, as the frame appears to have been tweaked and the alignment on the RH front tire must be off from the way it's been chewing the tire. LH front looks good.
Also curious about mounting the CV brake booster/master cylinder and pedals if you have the time... And the gauges, did you remove the clear lens off the CV gauges to get them to fit?
  #84
Old 12-17-2015, 11:31 AM
jgandy24's Avatar
jgandy24
jgandy24 is offline
Again, I know this is an old post but I have a 77' F100 Ranger; 302 built and now I am in the process of body work, paint, wiring..etc... SO this thread and build is for sure some great motivation!!!!!
Awesome looking truck SP!!!!!
  #85
Old 01-30-2016, 10:48 AM
Kendal's Avatar
Kendal
Kendal is offline
looking good more pics please
  #86
Old 11-26-2016, 03:05 PM
72-F100-4V's Avatar
72-F100-4V
72-F100-4V is offline
Diggin from the dead. Here is hoping that SkinnyPedal comes back. I have some questions about your wheels and how the truck is doing after all these years.
  #87
Old 11-26-2016, 08:41 PM
SkinnyPedal
2016 Update
My son still drives ClifFord everyday and I jump in it every chance I get.
ClifFord has 42k miles on it as of today. 11/26/2016
We did drive it to Daytona and back from north east Tennessee in the spring of 2016 for bike week. We pulled the bikes down with it.
We have built 4 others since this build and have plans to build me one.
I have already purchased a 1968 f100 and the donor car. Hope to get started on it soon.
build thread Coming Soon 2017; "BuFord"
  #88
Old 02-12-2017, 03:13 AM
KILLemALL's Avatar
KILLemALL
KILLemALL is offline
Do you know what the factory color is?Thanks;-)
  #89
Old 02-12-2017, 07:14 AM
Motorhead351's Avatar
Motorhead351
Motorhead351 is offline
Awesome truck. I try to make the somerset show as often as possible.
  #90
Old 02-12-2017, 07:52 PM
SkinnyPedal
Thanks, We Really like that summerset show.
I'm not sure of the Color but it is OE.
Quick Reply: 1977 F-100 "ClifFORD" Crown Vic swap
