Help! Electrical issues - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-22-2013, 07:40 PM
919rider 919rider is offline
919rider is starting off with a positive reputation.
Last night my daughter kept her heated seat pad plugged into the accessory power point. Needless to say I wasn't happy about having a dead battery at 6:50am and -7 degrees F!!
I hooked up my wife's Flex to my truck w/ jumper cables, and waited 15 min or so. Barely a tick. Then I remembered that my el-cheapo, Chicago Electric, battery charger has a 55A "engine start/boost" feature. I hooked that up and the truck fired right up!! Disconnected everything, did some running around town before hitting the high-way and heading to work. Truck functions normally, however, I've got some electrical items that are not working. I checked the fuse box, and all the fuses that I checked (all that are related according to the owners manual) are fine.
Items out:
Dome lights
Instrument Panel
Radio
Auto headlamp function (when I flip the switch for headlamps, everything works, as well as the interior lighting (ie, radio lights up, instruments light up, etc. Still no dome lights or map lights.)
Most of the idiot lights are illuminated, but I have no indication from any of the gages (fuel might be working, my wife had run me mostly dry and I didn't look at it after I filled up.)
Any idea's what I need to check? Not fun poking around in the dark and cold, but that's what I'll be doing between coming in here and hoping someone has a quick reply!!
Thanks!
Kevin
Old 01-22-2013, 07:45 PM
madsonp's Avatar
madsonp madsonp is offline
madsonp has a good reputation on FTE.madsonp has a good reputation on FTE.madsonp has a good reputation on FTE.
Did you try disconnecting the battery for a few minutes then reconnecting it to reset things? 5 minute reply, is that quick enough ?
Old 01-22-2013, 07:56 PM
Pretty quick. Nope, didn't disconnect the battery, but I'll do that now!
K
Old 01-22-2013, 08:07 PM
Damn, I just got lucky!!
I had checked most of the fuses that were related, but don't think I had checked 35 - Inst Cluster. Pulled it and its fine. Put it back in and the dome light clicks on.
Huh?
Pull it, dome light is out. Put it back in, its on.
Start truck. Gages and everything are working!
Don't know wtf that was about, but it appears to have fixed itself!
K
Old 01-22-2013, 08:17 PM
madsonp's Avatar
Glad your back in business Pulling the fuse could have reset things like disconnecting and reconnecting the battery will do, who knows.
Won't Start. About to beat the windows out of it. xc4jokestomper 1987 - 1996 F150 & Larger F-Series Trucks 12 08-11-2012 11:45 AM
electrical issue with front map light resq302 Explorer, Sport Trac, Mountaineer & Aviator 15 02-23-2012 07:28 AM
Electrical Problems hooking up Aftermarket Radio ExcursionBoy1984 Excursion - King of SUVs 0 02-03-2010 07:56 AM
Electrical Outage Issue kapdma 6.0L Power Stroke Diesel 7 12-30-2009 01:02 PM
windows,radio,dome light don't work Navy7797 1999 to 2016 Super Duty 2 01-13-2008 03:10 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
