powerstroke Water Pump Lower Inlet O'Ring repair - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 01-22-2013, 05:41 PM
TheBoneSentYea TheBoneSentYea is offline
TheBoneSentYea is starting off with a positive reputation.
I found a leak a coupe days ago and pin pointed the location, its coming from the lower inlet on the water pump. Some diesel guys online said that there is an O-ring that tends to go out and needs to be replaced. Here are some pictures.
Also, if it turns out to be an )-ring issue can i repair it from underneath the truck? instead of pulling out the serpentine belt, and clutch fan ect..
http://s1170.beta.photobucket.com/us...tml?sort=3&o=0
Old 01-22-2013, 05:42 PM
Old 01-22-2013, 07:25 PM
A/Ox4's Avatar
A/Ox4 A/Ox4 is offline
9 ECHO 1
A/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputation
You can get the oring a dieselorings.com or riffraffdiesel.com. It's pretty easy to replace from the too or bottom.
Old 01-22-2013, 09:48 PM
petrokiller's Avatar
petrokiller petrokiller is offline
petrokiller has a great reputation on FTE.petrokiller has a great reputation on FTE.petrokiller has a great reputation on FTE.petrokiller has a great reputation on FTE.petrokiller has a great reputation on FTE.
Presoak those bolts if you can, I had trouble getting mine apart. Ended up getting a 6 point box end wrench.
12 point was stripping bolt head.
Grabbed my oring at Autozone, thermostat gasket is different size.
Search my post for pics. http://www.ford-trucks.com/forums/12...ater-pump.html
Tell autozone you want lower water outlet gasket. I ended up getting both Thermostat/ Lower and and picked once i removed which 2 use.
Old 01-22-2013, 09:56 PM
part number 3561-1 for lower oring.
Also put a lite coat of rtv silicone around new oring before mating back 2gether. Just aids in a better seal.
Hope this helps. PRESOAK BOLTS
Old 01-23-2013, 02:21 AM
DND58's Avatar
DND58 DND58 is offline
DND58 has a good reputation on FTE.DND58 has a good reputation on FTE.DND58 has a good reputation on FTE.
Had same leak a couple years ago. As temp changed, so did leak. I drained to a couple clean 5 gal buckets and removed pump inlet elbow from below. Used plenty of PB blaster early on the bolts. Bought the o ring from dealer part #F81Z-8255-AA. Cleaned up elbow with wire brush, and lubed o-ring with faucet lube.
Old 01-23-2013, 05:44 AM
Supercab Supercab is offline
Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.
-Years ago this was discussed and many suggested using the O ring seal that is normally used for the thermostat housing.
-I had the same leak as the OP has, MY water pump was only a year old at the time.
-I took mine apart and used the thermostat seal and plumbers faucet lube (NO RTV) and it sealed up just fine.
Old 01-23-2013, 12:36 PM
thanks guys for all the help, looks like ill be getting after it later on today
Old 01-23-2013, 05:21 PM
Let us know how it goes. I barely used any RTV, just enough to aid in the seal.
Old 01-23-2013, 09:02 PM
Well, job is done. Pretty easy to do hopefully the gasket was the issue. I removed the neck that bolts onto the water pump and instantly noticed gunk and grime around the gasket, started to remove the gasket and it crumbled apart. After cleaning the shaft or neck really well i then put on the new O-ring and sealed it with VersaChem - Mega Blue Silicone. Bolted it back on, put everything back together, and then filled my truck up with 50% distilled water and 50% Antifreeze/Coolant Peak HD - Engine Coolant / Anti-Freeze
Antifreeze/Coolant Peak HD FLEET - Engine Coolant / Anti-Freeze | O'Reilly Auto Parts
is this stuff going to be okay?
Anyways it started to rain and i will get back once i know if the leak is fixed or not.
Test J ballan Testing..... 0 01-27-2015 08:57 PM
Water transfer camo ford badge rlgade 1999 to 2016 Super Duty 5 05-22-2014 12:57 PM
My 64 F100 64jjwf100 1961 - 1966 F-100 & Larger F-Series Trucks 9 02-07-2014 02:08 AM
Ranger Stepside/Splash Bed Extender ViLo Ranger & B-Series 3 12-29-2013 04:26 PM
camo paint scheme comments jaagen 1987 - 1996 F150 & Larger F-Series Trucks 39 01-26-2013 09:09 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
