Window Weaterstripping
Old 01-22-2013, 12:23 PM
nick5446's Avatar
nick5446
nick5446 is offline
Has anyone found a good generic substitute for the window (not door) weatherstripping on these trucks? I know you can get the cut to length stuff from LMC and others, but I was hoping to go to the parts store and grab a roll.
Also, am I correct in my thinking that it's a single piece that goes from the bottom of one track, up and over the window, to the bottom of the other track? About 8 feet long? I'm imagining it's a "U" shaped cross-section about 1/2" wide, 1/2" tall and about 1/8" channel about 1/4" deep.
Don't be jealous of my drafting skills
Old 01-22-2013, 06:04 PM
spurredon's Avatar
spurredon
spurredon is offline
It's one piece from the bottom rear side of the glass run to the top front side, ending at the divider bar. Haven't seen any generic stuff but the suppliers get it somewhere to make up the kits.
By the way, your demension line weights should not be as heavy as your object line weights!
Old 01-22-2013, 08:48 PM
nick5446's Avatar
nick5446
nick5446 is offline
5 years of engineering school baby!
I didn't quite follow your explanation, are you saying it's two pieces per side? Maybe I'll take some measurements and go to the parts store.
Old 01-23-2013, 09:45 AM
iggy.ho's Avatar
iggy.ho
iggy.ho is offline
Yes, it is two pieces. I don't think you can make that bend on top front with one piece. I've used some generic welting in the past, shredded after a couple of years! Had good luck with steele rubber co. products.
Old 01-23-2013, 10:43 AM
nick5446's Avatar
nick5446
nick5446 is offline
Good point! Thanks!
Old 01-23-2013, 04:28 PM
spurredon's Avatar
spurredon
Yeah, like iggy, said it's not just one piece that goes around the whole window. I guess my explaination was a little "scketchy", as well.
51fordf5
06-22-2014 06:32 PM
Flathead 51
02-20-2010 12:48 PM
mcn420
1997 - 2003 F150
11-28-2005 01:44 PM
JoeKramer
01-14-2005 03:49 PM
Kliphton
Appearance & Dress-Up
05-26-2004 09:35 AM
Quick Reply: Window Weaterstripping
