Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 01-22-2013, 12:23 PM
nick5446 nick5446 is offline
Garage is empty, add now
nick5446 is starting off with a positive reputation.
Window Weaterstripping
Has anyone found a good generic substitute for the window (not door) weatherstripping on these trucks? I know you can get the cut to length stuff from LMC and others, but I was hoping to go to the parts store and grab a roll.
Also, am I correct in my thinking that it's a single piece that goes from the bottom of one track, up and over the window, to the bottom of the other track? About 8 feet long? I'm imagining it's a "U" shaped cross-section about 1/2" wide, 1/2" tall and about 1/8" channel about 1/4" deep.
Don't be jealous of my drafting skills
Click the image to open in full size.
  #2 (permalink)
Old 01-22-2013, 06:04 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
It's one piece from the bottom rear side of the glass run to the top front side, ending at the divider bar. Haven't seen any generic stuff but the suppliers get it somewhere to make up the kits.
By the way, your demension line weights should not be as heavy as your object line weights!
  #3 (permalink)
Old 01-22-2013, 08:48 PM
5 years of engineering school baby!
I didn't quite follow your explanation, are you saying it's two pieces per side? Maybe I'll take some measurements and go to the parts store.
  #4 (permalink)
Old 01-23-2013, 09:45 AM
iggy.ho iggy.ho is offline
iggy.ho is starting off with a positive reputation.
Yes, it is two pieces. I don't think you can make that bend on top front with one piece. I've used some generic welting in the past, shredded after a couple of years! Had good luck with steele rubber co. products.
  #5 (permalink)
Old 01-23-2013, 10:43 AM
Quote:
Good point! Thanks!
  #6 (permalink)
Old 01-23-2013, 04:28 PM
spurredon's Avatar
Yeah, like iggy, said it's not just one piece that goes around the whole window. I guess my explaination was a little "scketchy", as well.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
