87 f250 speedometer bouncing.
I just bought a 87 ford f250 4x4 with the 5.0l and a manual 4 speed tranny. i have only had it for 2 days and the speedometer just started bouncing above 40 mph. it bounces from 45-90. Is this a cable driven speedo? If so where does the cable hook up ( tranny or transfer case)? i havent been able to crawl under it today to look but i would like to find out before i dig in tonight.
Thanks i checked it out today and the clip on the cable where it attaches to the t case was gone so i replaced it and hopefully that will fix it. but on the way home i noticed that the truck wasnt heating up past the lowest line in the normal range. so i swapped out the radiator cap and no change and i had to fill up for the first time and the rear tank wont let me put any fuel in it and its bone dry and the front will let me fuel up but i have to hold the fuel pump slow so it takes about 15 minutes to fill. Any suggestions? im starting to think i bought a lemon.
Received 3,090 Likes
on
temp gauge is not very accurate. if it has heat, don't worry about it reading low.
the rear tank may be blocked off due to bad selector switch. as for the slow fill, try driving up on a 6 inch block next time. that is what i have to do to fill my 88 diesel.
it has something to due with the tank vents.
80skeys
06-12-2010 03:05 PM
stangbanger
07-10-2009 07:25 PM
RTM
02-19-2004 04:29 PM
250-highboy-76
02-15-2004 03:06 PM
