2005 f-150 FX4 blower issues - Ford Truck Enthusiasts Forums
Old 01-22-2013, 07:01 AM
burd50 burd50 is offline
burd50 is starting off with a positive reputation.
I was wondering if anybody has an suggestions for a problem I'm having? Whether in heat or AC mode and any dial position, I'm not getting nearly enough air blowing out of the vents to cool or heat the cabin in a timely manner. The fan switch is working in all positions but I have to use high speed all the time to get enough air to defrost the windshield. I've also noticed that when defrost is selected, air only comes out on the inside part of the vents, not the outside. Is there a cabin filter on this truck, I've checked auto parts stores and they don't list anything for it. Any help would be appreciated. Thanks
Old 01-22-2013, 08:23 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Chances are, the evaporator core is covered with dust, pollen, crud, or a critter's nest.
Pull the blower motor out and do a visual inspection on the plenum and the evaporator core.
Old 01-23-2013, 06:44 AM
Got it, thanks. I'll have to try that and see if it works.
99 v10 Triton Superduty heating issues CurtisNova 1999 to 2016 Super Duty 2 02-24-2014 11:32 PM
Main cabin air blower not working 4.0 Beast Explorer, Sport Trac, Mountaineer & Aviator 6 01-06-2011 11:21 PM
2006 Ford F250 In-Cabin Filter Woes? swedepowr1 1999 to 2016 Super Duty 8 09-03-2008 10:53 AM
heat issue brain teaser: cool air in floor & defrost position, warm air at mid level Eric_F250 Cooling, Heating, Ventilation & A/C 4 09-02-2007 12:06 PM
air vent control wurthitpaul 1997 - 2003 F150 3 09-14-2003 12:51 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
