computer #cross reference HELP! - Ford Truck Enthusiasts Forums
Old 01-21-2013, 09:55 PM
casweco casweco is offline
casweco is starting off with a positive reputation.
Unhappy computer #cross reference HELP!
I have a 90 F-150 4x4 5.8 with the push button overdrive and the computer went kaput. F0TF-12A650-N2A, EOD is the computer that I pulled out and am having a heck of a time finding an exact replacement (dont want to spend $300 for a used one off e-bay). Do I absolutely have to use the same computer or what other computers might/will work? Any and all suggestions/opinions will be greatly appreciated.
Old 01-22-2013, 08:06 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
It would help you out a lot when looking for this computer if you would use a zero and not an "O" in the computer number.
The number is F0(zero) and not FO, big difference.
You used an "O" in the the posting above.
Also look for it using only the F0TF-N2A as an alternate number.
Old 01-24-2013, 06:48 PM
well plugged in a F0TF-12A650-BPA computer and it fired right up and is mobile again.
swap Dawgbite14 1997 - 2003 F150 2 10-14-2016 12:13 PM
1997 Computer change for diagnostics jeepnatv4life 1997 - 2003 F150 20 11-29-2015 06:15 PM
94 computer in a 95 junkyardjeff 1987 - 1996 F150 & Larger F-Series Trucks 3 03-25-2015 07:52 PM
ecm computer problem scoobydum Computer Chips & Tuners 3 06-10-2012 07:59 AM
Overhead Trip Computer-Lariat pkg. whatluckfarm 1999 to 2016 Super Duty 9 07-22-1999 12:01 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
